need help! b18a1 in 93 si wont start
Old Sep 23, 2015 | 12:02 PM
siboost93's Avatar
Icon4 need help! b18a1 in 93 si wont start
i just dropped a b18a1 unto my 93 si it came out of a 92 hatch i have spark and fuel but wont start, every now and then it stumbles a little like its close but no cigar. im using the stock p28 ecu cuz i was told it would work. this is my first dohc ive only had sohc turbo setups prior to this im trying to get it running before i swap an itr head on it. was wondering if there are differences in firing order or something along those lines, i tried to search through the threads with no success. any help would be greatly appreciated thanx in advance
Old Sep 23, 2015 | 12:06 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: need help! b18a1 in 93 si wont start
Firing order is the same. Have you verified that your mechanical timing is correct?
Old Sep 23, 2015 | 12:10 PM
siboost93's Avatar
i didnt but it was running in his hatch he pulled it out and i picked it up
Old Sep 23, 2015 | 12:17 PM
24TEN's Avatar
PHANTOM MENACE
I'd still verify.
Play with ignition timing via the distributor? And I'm going to guess previously it was running on the correct ECU?
Old Sep 23, 2015 | 03:23 PM
NotARaCist's Avatar
I never narc'd on nobody!
You're using the wrong ECU. Get the correct ECU, and work from there. Whoever told you a VTEC ECU would work properly for a non-VTEC engine is a ******* idiot.
dloc82295
Nov 27, 2012 09:14 AM
CbGirlSi
Feb 12, 2005 05:46 AM
93DA530
Nov 24, 2003 11:10 AM
