anyone using an oil cooler?
Old Nov 5, 2002 | 03:05 PM
Boostless97Lude
Guest
Posts: n/a
Default anyone using an oil cooler?
i read a thread in FI about oil coolers, but no one had a god answer about a Prelude, since we have those cool little liquid oil cooler at the filter, i was wondering if anyone is using a oil cooler.... pics would be helpful
Old Nov 5, 2002 | 03:56 PM
BoostedH23a1's Avatar
Default Re: anyone using an oil cooler? (Boosted97Lude)
im trying to find a nice crome one like greddy but i dont wanna pay 450 for a damn oil cooler and i dont want B&M
Old Nov 5, 2002 | 04:00 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: anyone using an oil cooler? (BoostedH23a1)
i am thinking of getting a universal Mocal cooler from http://www.racerpartswholesale.com and just making my own steel lines
[Modified by Boosted97Lude, 8:02 PM 11/5/2002]
Old Nov 5, 2002 | 04:17 PM
PrecisionH23a's Avatar
You guys are cheap Greddy is the one i plan on getting
Old Nov 5, 2002 | 04:18 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: anyone using an oil cooler? (GudeH23a)
yeah, well, that's a lot of freakin money
Old Nov 5, 2002 | 05:16 PM
DirtyLude's Avatar
The Mocal cooler is high end. You can't go wrong with that.
Clendaniel has one of the niciest setups I've seen. It's not braided line or anything, but he set it up with a remote filter and everything bolted to the front cross member. I wonder if I can find his pictures and steal them for this thread.
Old Nov 5, 2002 | 05:28 PM
DirtyLude's Avatar
Default Re: anyone using an oil cooler? (DirtyLude)
I guess it is braided.
Old Nov 5, 2002 | 05:37 PM
DirtyLude's Avatar
That last one was based on a B&M cooler. This one is a real Mocal cooler. It's from BDBs' car from Ottawa. The silver metal hose holder thing is a the oil filter and thermostat which is a good idea to have.
[Modified by DirtyLude, 9:39 PM 11/5/2002]
Old Nov 5, 2002 | 06:04 PM
Bad ***! where did u get that one. and how the hell does that small *** battery work on a lude. whats the CCA on that bastard?
Old Nov 5, 2002 | 06:27 PM
Boostless97Lude
Guest
Posts: n/a
for real... i no longer give a damn about the oil cooler, i want to know where you got that battery
Old Nov 5, 2002 | 06:34 PM
apexii's Avatar
What does having that extra length of hose do to oil pressure? That has always been one of my main concerns with setups like that.
Old Nov 5, 2002 | 07:40 PM
clendaniel's Avatar
Default Re: anyone using an oil cooler? (apexii)
my pressure sender for the oil pressure guage is tapped into the bottom of the filter housing....I didn't notice any change in pressure, it's still over the spec given in the helms manual. The biggest difference is in oil capacity, with the motor totally empty it took a hair over 8qts...takes a tad over 6 on a regular change.
--Ian
Old Nov 5, 2002 | 08:20 PM
Anubyss's Avatar
Default Re: anyone using an oil cooler? (clendaniel)
Damn I want an oil cooler. Mocal setup would be sweet. Don't have enough cash saved up for it yet though. $500 for an oil cooler setup seems worth it to me for turbo preludes. Did you install that yourself Clendaniel (I may have asked you this before)?
Old Nov 6, 2002 | 12:36 AM
--Ian
6 quarts... are you ******* serious?
Old Nov 6, 2002 | 01:20 AM
4bidden's Avatar
i think thats the odyssey pc680 battery...
look here for specs... http://www.odysseyfactory.com/specs.htm
[Modified by 4bidden, 10:20 AM 11/6/2002]
Old Nov 6, 2002 | 04:19 AM
apexii's Avatar
--Ian
I first misunderstood this, I think he means it now takes 6 qts during an oil change, but took 8 for the first time he filled the motor up. 1qt extra would make sense for the given amount of braided line he's running.
Old Nov 6, 2002 | 05:50 AM
clendaniel's Avatar
Default Re: anyone using an oil cooler? (Anubyss)
Yeah, I did it all...most of the money's in the an fittings and line. You weren't dreaming when you said it wasn't stainless originally. When I rebuilt the motor I decided to upgrade it and my fuel lines to stainless as I never liked the idea of my engine oil routed through plain rubber hose and brass barbs. I got most of the pieces through amstreetrod.com. He's pretty quick and is straight with you about when you'll get things if it isn't on hand. I think I said in a post on p-o.com that there are a couple things I'd have done differently and may change in the future. The biggest one was using a 90 degree on the left end of the cooler and then moving the 180 to output behind the filter as it would look cleaner and eliminate the loop. The only problem is I'd already drilled and tapped for the pressure sender which now blocks that path so I'll leave it as is. I'm thinking of swapping the cooler from the B&M unit to the Mocal...no big deal, my fittings will thread into the mocal. The adapters won't change as I can't see the mocal ones being any better and the rest of the system is all stainless and an fittings so they're fine too.
--Ian
Old Nov 6, 2002 | 05:54 AM
clendaniel's Avatar
Yeah...it's only another quart or so. You figure there's about 10-12ft of an-10 line and a cooler added to the system.
--Ian
Old Nov 6, 2002 | 10:12 AM
mugenbb6's Avatar
Greddy makes one for the 5th gen? Is the Jackson Racing oil cooler any good? They have a kit for the 5th gen.
hardparked_ehtwo
Jan 11, 2008 06:12 PM
adseguy
Feb 7, 2005 01:43 PM
Boostless97Lude
Oct 19, 2004 01:23 PM
gsrhunny
Aug 7, 2003 11:36 AM
