Need help on Honda Forza NSS250A8
Old Sep 22, 2015 | 08:59 PM
Anh Nguyen's Avatar
Default Need help on Honda Forza NSS250A8
Hi,
My scooter Honda Forza NSS250A8 with S-Matic transmission system on it. My problem is :
- Under setting riding mode "D" or "S", after riding for awhile the dash board indicate "F" flashing 5 short times - stop - then repeat flashing the same, engine still running but the bike only can run under operation like in 1st gear. When I swift off the ignition button then turn it on, the bike return normal operation. There are not any symptom before "F" flashing, also the frequency happening different time to time.
- While riding in "A" or "M" mode without any problem.
In my country, Vietnam, seem could not find the right workshop who have experiences for this bike. Myself even have not the service manual on hand so I do not know what should I do check now.
Can anyone help me out, thank you so much!
ANH,
Old Jun 9, 2017 | 12:45 AM
gschan's Avatar
Default Re: Need help on Honda Forza NSS250A8
Ahn,
Were you able to fix the problem with your Forza? I have the same problem with my 2008 Forza Z here in Manila, Philippines and have not been able to fix it for the past couple of months. Getting very desparate already. Mine is flashing the "F" 8x.
Hoping to be able to get some help from other Forza owners.
Regards,
Gilbert
Old Jun 9, 2017 | 02:13 AM
Anh Nguyen's Avatar
Originally Posted by gschan
Ahn,
Regards,
Gilbert
Good day Gilbert,
Finally, here are few step that I did check and fixed the issue on my Forza:
1. Check the sensor right above the front pulley. This was checked by techincan as they have the testing machine. Make sure it still works well or not.
2. Check the working status of front pulley, bad surface condition or being used too much, you need to replace the new one. It is similar with my case, so the V-belt did not going correct direction then cause the sensor reading ""error"" data.
Hope you can fix your problem soon.
Anh,
Old Jun 11, 2018 | 09:14 AM
Quangbu278's Avatar
Hi Anh
Minh dang o VN va cung bi loi nhu vay, Anh co the tu van giup minh khong, nt cho minh nhe, minh se goi lai
0907.399.099 Bao
Tks
i_VTEC
Honda Motorcycles
23
Sep 5, 2014 04:16 PM
av_shadow700
Honda Motorcycles
Jun 7, 2011 08:25 PM
SveinRC51
Honda Motorcycles
Dec 31, 2006 07:08 AM
fabdra
Honda Motorcycles
Jun 3, 2004 07:28 AM
umar456
Honda Motorcycles
Jul 20, 2003 08:35 PM
