Setting time on gsr with crower valve springs issue
Old Sep 21, 2015 | 07:18 PM
H22egguy's Avatar
Default Setting time on gsr with crower valve springs issue
Hey guys so I'm wrapping up a full build on a gsr and the customer ran Brian crower dual valve springs with crower stage 2 turbo cams with skunk2 gears. Once the cams are in the journals and the cam caps are on,vtec cams have no slot for a wrench to turn the cam to compress the springs. I've never used the tool that locks the cam gears in place... We may have to purchase one. Anyone have any suggestions
Old Sep 22, 2015 | 03:15 AM
blackeg's Avatar
Default Re: Setting time on gsr with crower valve springs issue
I just use either a phillips screwdriver or a punch pin of appropriate diameter to hold the cams in place never had an issue
Old Sep 22, 2015 | 10:39 AM
H22egguy's Avatar
yeah I've used the punch on a non vtec camshaft... the have a hole on the gear end to place the punch. where are you placing the punch/screw driver on a vtec cam?
Old Oct 6, 2015 | 09:49 PM
H22egguy's Avatar
for anyone curious with a similar situation we ended up over torquing the cam gear bolts 7lbs so that we could rotate the cams by the bolts.
FULLY_BUILT_NA
Oct 11, 2005 06:50 PM
95BlkGSR
May 7, 2004 07:41 PM
integraautox
Oct 7, 2002 11:39 AM
SCsol
Jan 28, 2002 11:04 AM
