B16 stroker
Old Sep 21, 2015 | 01:23 PM
Lopallo's Avatar
Default B16 stroker
Hi
I am looking for stroker my b16a2..
Is posible b20, b18 gsr LS or B17 crank with ek9 pistons right?
What is the lenght fit for the rods?
I look forward your replys.
Thanks
Regards
Old Sep 21, 2015 | 03:25 PM
TravisBiggie's Avatar
Default Re: B16 stroker
yeah, a LS crank (won't work in a b16 block)
77mm stroke to 89mm stroke is pretty sweet.
one reason why I will NEVER own a b16.
Old Sep 21, 2015 | 04:41 PM
whitesihatch's Avatar
why would you ruin a completely good r/s ratio.
if you want displacement find a ls, b20, gsr block and build from there.
Old Sep 21, 2015 | 08:41 PM
m_shake's Avatar
A B17 crank is probably the only thing thats gonna fit and offer a decent rod stroke ratio (as far as oem cranks are concerned) Buy a b18 of some sort or a b20, unless you must have the b16 block for some reason its a waste of time and money to do that much work to a b16.
Project_SOHC_EX
Nov 10, 2009 10:48 AM
turbob16ef
Dec 13, 2006 09:54 AM
CircuitFG
May 4, 2005 01:19 AM
agreziv89ef-8
Apr 24, 2004 04:39 PM
civic-si-2000
Apr 23, 2004 01:10 PM
