Extremely uneven coilovers!
Now I know these are some brand of cheap eBay sleeved coilovers so they are crap but they came with the car I just bought but I am trying to figure out a puzzle. Both the front and the back have the same problem. When trying to match the ride height both the front and the back are off by about 3 to 4" from each other when measured on the coilover. As in I can slam one side as you should be able to with these but the other will not even get the tire within 2 inches of the fender. I.E. one side if you lower collars all the way down will tuck the tire and become almost unrideable while the other side will have a 2" gap from the tire to the fender. Any ideas what would cause this? I am lost. I just want to make sure something is not out of whack or something?
Can you support the front of the car and remove both front coilovers and check out a side by side comparison? That's probably where I would start. Almost seems like it's two different kinds on each side.
If the "low" side is the driver's side then maybe the previous owner is fat-**** and wore that side out..lol
Ever notice how a lot of big people drive small cars? Especially, big women.
And I know the coilovers are or at least look upside down! But that is the difference to try to even them out and the one that is all the way down is still a good 1 to 2" of gap between the tire and fender. It is on stock tire size and each coil measures about 7.25 and each sleeve is about 5.25"
I checked the other side and they are both sitting up evenly like that. I know it should be seated but that wouldn't account for that much difference side to side I would think. Plus the back is the same just opposite. So I am maxed out of the drivers front and passenger rear.
Lol! Surprisingly they still take good pressure to collapse. No noise at all and smooth motion. Remember the the ones that are maxed out on low setting are giving me the highest ride height!
I'd take everything out and lay it out in front of you on the ground. Might have a better visual of what's really going on then. Also would give you the chance to closer inspect the rest of the suspension components. I know you already covered it, but I'd be leaning toward different length springs, and two fronts on one side of the car. Just my immediate guesses.
My coilovers were off a bit too. I took me many hours before I finally found out I got the best result by adjusting the collars, lowering the car back down to the ground, then pushing down on the hood/fender in a rocking motion with most of my body weight. It helped settle the coilovers much better because I noticed that every time I went to adjust one, it would throw another (or more) out of measurement. It was so annoying lol.
Cool Cool Island Breezes. BOY-EE
Other way around.
If you have to adjust them upward to get the same height as the others, they're probably the softer of the two.
I'd put the softer ones in back instead of what you're planning.
Edit: I'm probably mixing up what you're saying. Either way...soft springs in back.
If you have a couple hundred $$ to spare, you can buy yourself a decent setup and forget all your troubles though, lol.
