Dim turn signal lights on cluster
So I am having this problem since around 2 weeks. Car is civic eg8 with Sir cluster.
Now let me explain the problem in the best way I can...
1. When car is running without any headlights or a/c turned on, the turn signal lights on the cluster are rather dimmish, but clearly visible. Left signal is more dimmer than right signal.
Why I say dimmish? Because I have compared with the hazards, and when the hazards are switched on, they both light up nice and bright on cluster.
2. When car is running with headlights turned on, no a/c, the turn signal lights on the cluster get more dim, like half the brightness. Again, left signal is more dimmer than right signal.
In this case as well, both lights on cluster turn on nice and bright when hazard is switched on.
3. When car is running with headlights turned on, and a/c as well, the turn signal lights on the cluster get even further dim (almost dead), and on lower rpms (like 800 to 1500) it totally blacks out.
Now something else to note, is that the rpm needle bounces with the turn signal tick-ticks on low rpms (800). I feel its like proper voltage is not reaching the cluster when using turn signals.
Even though I am sure the problem is not in the cluster since lights are turning on just fine with the hazards, I still took out the cluster to have a look and found it in order. Jiggled the wires a little to see any change, but none.
I also tested this: Turned on left turn signal with headlights and a/c on, and the turn light on cluster was very dim (almost dead). Simultaneously, I turned on the hazards and both turn signals were full bright.
I also unplugged and replugged the hazard switch (which was a normal procedure when taking off the a/c grill to reach the cluster).
Need suggestions as to what I should check; I have no clue right now.
The external turn lights are lighting up regardless.
Edit: I just realized I wrote a story book :p
I bet your alternator is going. Just a guess from a guy who never replaced one on a civic but I think I'm right none the less. Any shop can check how much power it is generating in a few minutes.
Had that been the alternator, dont you think other lights in the cluster, or any other light on the dashboard or on body would have been affected as well?
So i switched the turn signal / hazard relay from an EK into my car. Still the same problem.
Its so confusing as the turn signal and hazards both use same wires to indicators (green/blue and green/yellow), but on turn signals the problem exists and not on hazards :/
Any suggestions?
Any suggestions?
Getting around 13+ without load, and around 11.5 to 12v with load (headlights and a/c) on both (fuse 15 and yel wire).
With the turn signal turned on, the voltage on Yel wire gradually goes down to under 10v (within 30 seconds); only when the turn signal blinks of course.
With hazards are turned on, just slight change in voltage (drop of around 0.1v to 0.3v).
So whats the culprit here?
I just replaced the alternator in my civic. It is measuring 14.5volts without load. The ELD (electrical load detector) will vary the voltage depending on the load. I've talked with master honda techs and they've all agreed that the civic runs a slightly higher voltage, normally. Also, if you check the FSM (factory service manual) it will also tell you that under 15v is normal.. 11.5 volts with load is way too low, the battery is not being charged at anything below 12.3-12.5 volts! You're draining your battery instead. so....
You need to get the alternator tested before wasting your time guessing. you could be here all year wondering what it is.. get it tested, simple answer, simple solution. Plus you need to also test out fuse 15, it's wiring harness was known for wearing and causing issues.
Even then, hazards should also be dimming the same way if we make the alternator responsible.
Nevertheless, I will have the alternator checked out.
I will also test voltage on the external lights. They light up fine so I am assuming they are getting enough voltage, but I could be wrong.
I also just tested the green/blue wire coming out of the hazard switch (engine off, ignition on), and its giving out around a weird voltage starting from 8.5v to gradually dropping to almost 0v, and then coming increasing back to around 8.5v and gradually dropping again; although no such affect on the lights they still are turning on at same brightness (slight dim for turn signal and full bright for hazards). This is the case with both hazard and turn signals.
philkehn
Sep 19, 2006 12:38 PM
snuggles
Apr 7, 2005 10:58 PM
snuggles
Jun 10, 2004 08:47 PM
