GSR brake swap.......VX rims?
Like the topic, I've got a 92 civic VX, have the possibility of picking up a 94 gsr brake swap, front and back. Wanted to see if the brake unit will fit under my VX rims? 13in.... feel like i'm cutting it close, wanted to see what people thought.
why don't you just upgrade to EH3 rear discs and get some better pads and rebuild your calipers with some better rotors. This should be plenty of stopping power for now unless you plan on doing some high speed touring or something of the like.
13" wheels will fit over front GSR brakes/calipers ONLY with the use of spacers to set the wheel out farther away from the caliper.
you can buy spacers from H&R.
the roadrace/autocross forum had a thread on this a while ago... top level national GSR racers use 13x8" rims! WOWSAAAAH!
okie, it the event that we think the si calipers will fit it, should i go for a rear SI disk swap for 300? which has "prop valve and master cylinder, ebrake cables, new pads and rotors were recently turned" sound like a good idea? Then get a set of spacers for just my rear and go for an upgrade later on the front?
Couter.....email me at jdmspoonsol@hotmail.com ......interested in doing the GSR Conv. on my car.... thanks
so do we think that 300 is a good price for the SI rear brake swap with master cylinder, prop valve, ebrake cables and semi new pads and recently turned rotors? And with spacers I'll be able to fit my 13s over the rear brakes?
[Modified by splitime, 1:48 AM 11/8/2002]
ravenger
Honda Civic (2001 - 2005)
Oct 22, 2007 03:29 PM
