possible bent LCA or more?
Old Nov 5, 2002 | 02:34 PM
djay86's Avatar
Default possible bent LCA or more?
alright guys... few weeks ago i was driving in the rain missed judged a turn , and hit a storm drain curb, my rota SS, bumper, and fender took the blow. the rim was cracked and a pretty big peice of it missing.
Today i finally got around to checking it out and it looks as if the passanger side wheel is pushed 2-3 inches back
Cant get a picture just yet, but here's an idea..
Anyway, do you think I just bent my LCA? How expensive/ hard is the fix if it is the LCA.. and is it drivable? Thanks guys.
[Modified by djay86, 6:34 PM 11/5/2002]
Old Nov 5, 2002 | 02:44 PM
JoshDM's Avatar
Default Re: possible bent LCA or more? (djay86)
lower cont. arm L. part#51365-sh3-020 $148.91
lower cont. arm R. part#51355-SH3-020 $148.91
usually that is all that needs to be replaced, be sure to get an alignment after install
Old Nov 5, 2002 | 02:54 PM
djay86's Avatar
Default Re: possible bent LCA or more? (JoshDM)
do i need both L and R
Old Nov 5, 2002 | 02:58 PM
JoshDM's Avatar
no, you never mentioned what side you hit, so I just put both numbers down
L.=drivers side
R.=passenger side
Old Nov 5, 2002 | 03:06 PM
Home Skillet's Avatar
My car is the same way. This is the only picture I could find of the front passenger side wheel. I changed the lower control arm and it still sits back 2 inches. I fell asleep at the wheel and smacked a curb
Old Nov 5, 2002 | 03:16 PM
Chiovnidca's Avatar
It takes a pretty hard hit to break a rim and move it back 2-3 inches. I wouldn't be surprised if there is more bent than the lower arm. The knuckle and beam are probably screwed too.
Old Nov 5, 2002 | 06:42 PM
djay86's Avatar
ttt
Old Nov 5, 2002 | 09:16 PM
CRX7's Avatar
The control arms are pretty solid pieces, it's the frame bars which support them which I think would go first
Old Nov 5, 2002 | 09:54 PM
kshymkiw's Avatar
Default Re: possible bent LCA or more? (CRX7)
ok i did this in a previous car.
the things i bent were the Lower Control Arm, The stabilizer Bar, and the Subframe. You may have bent the subframe depending on how hard you hit the curb. Those 3 things cost me about 400 bucks and a weekend to do. If you go to a shop to get those done expect to pay 2 grand rouglhy. hope this helps out some
Old Nov 5, 2002 | 10:06 PM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: possible bent LCA or more? (Home Skillet)
that's YOUR car!? i used to visit that/your site a looong time ago and wished the pics were bigger. small world.
Old Nov 6, 2002 | 07:07 AM
djay86's Avatar
Default Re: possible bent LCA or more? (Ham'ed Hatch)
ttt
Old Nov 6, 2002 | 08:19 AM
mini-cRx's Avatar
hey i got the same problem with mine cant figure out what it is
Old Nov 6, 2002 | 08:33 AM
JoshDM's Avatar
Default Re: possible bent LCA or more? (mini-cRx)
it also could be the rear beam, sometimes when hitting a curb it will bend the beam that will cause the wheel to sit back a little bit
it can either be bent back into place or just replaced
w/p.s. part#50200-sh9-a00 $428.40
w/o p.s. part#50200-sh0-a01 $428.40
either way you can't just do it at home it will need an alignment
DON'T DRINK AND DRIVE!
only smoke and drive
Old Nov 6, 2002 | 02:26 PM
upstatecrx's Avatar
struts are bend very easily so that might be somthing else to look into. if you can put your car up on a lift, measure points on the suspension to a hole that is in the body of the car. then measure the same spot on the other side and compare measurements.
Old Nov 6, 2002 | 03:24 PM
88'CRX'Si's Avatar
Default Re: possible bent LCA or more? (upstatecrx)
Bent A-arm... just replaced mine yesterday... same exact thing... cost 30 dollars with my own labor...
Old Nov 6, 2002 | 03:32 PM
my_slow_civic's Avatar
Default Re: possible bent LCA or more? (88'CRX'Si)
Ouch
On the other hand. I have everything from the rear suspension if you need it. LCA's trailing arms, and suspension. I just did a rear disc swap, and have mine sitting around.
Also, now is a good time to do the disc swap eh?
I have those too.
Old Nov 6, 2002 | 06:33 PM
Jared's Avatar
Default Re: possible bent LCA or more? (sirk)
probably uca as well. they are VERY weak.
Old Nov 6, 2002 | 07:26 PM
racerxadam's Avatar
You need to get it up in the air and look at everything. I would tend toward the upper control arm cause the lower seems like it would break rather than bend. Or the mounting point where the lca bolts to the frame could be bent. Really you should go to a shop and see if they will give you a print out of the underbody frame dimensions and you should check it out with a tape measure. Its not perfect but you will get an idea of where things are wrong.
Old Nov 7, 2002 | 08:23 PM
kshymkiw's Avatar
Default Re: possible bent LCA or more? (racerxadam)
I still say lower control arm, Subframe, knuckles and **** like that
Old Nov 7, 2002 | 08:38 PM
86_CRX_FOR_LIFE's Avatar
Default Re: possible bent LCA or more? (kshymkiw)
yea your control arm is gone. and i would check out your torson bar!!! every thing in that sides alingment i would check out!! curbs can be mean!! they just jump out right in front of you!!
Old Nov 7, 2002 | 10:08 PM
r7's Avatar
r7
Default Re: possible bent LCA or more? (86_CRX_FOR_LIFE)
smoked curb with wheels turned left
i can visibly see that i broke/bent, rim (sw388), lower control arm, torsion bar, fork/knuckle
which is the a-beam? or rear beam you guys refer to?
Old Nov 7, 2002 | 11:55 PM
kshymkiw's Avatar
Default Re: possible bent LCA or more? (r7)
ouch you broke you sw-388????? man i feel for you I know if i had some 388's you wouldn't see me parkin near a damn curb. Sorry about your luck on the 388's
Old Nov 8, 2002 | 04:07 PM
r7's Avatar
r7
actually, all 4 wheels went over the curb.. bald rear tires = bad
got new rim for 600$ CDN.. . kinda expensive, but not many people want to sell 1 rim
have yet to replace broken/bent parts, ie. lca,torsion bar, fork, etc.
it's winter here.
Old Nov 8, 2002 | 07:01 PM
djay86's Avatar
well, damn, you guys have been damn helpeful.. i think i should have explained me accident a lil more, my rim broke.. rota SS.. but i never went up onto the curb, the curb was really really high, becausae it was a storm drain ( also reinforced with steel) so that made impact a lil harder... but i just hit the curb, never went up on it... ive put about 300 miles on it since the accident.. alignment seems messed up.. and probs some other stupid stuff. does this help at all?
dHaybee
Suspension & Brakes
Apr 7, 2011 02:07 PM
I CRX I
Dec 24, 2006 09:28 AM
TealEG!
Suspension & Brakes
Oct 20, 2005 08:24 PM
opiumdaze
14
Oct 11, 2005 09:22 PM
Chris
13
Aug 14, 2001 11:47 PM
