Main Relay for a 93 del sol m/t
Old Sep 18, 2015 | 11:51 AM
donnieb22000's Avatar
Default Main Relay for a 93 del sol m/t
Just a quick question ok I got my new ecu off ebay today and it work fine but the car still would not start.So I did the 3 loop deal in the main relay harness plug? Where you just loop 3 wires in the bottom 4 hole's.And after doing it that way the car run fine. But you have to leave the wire"s in to keep it running.So some people say I need a new main relay but I bought one off ebay for like 20 buck's then I got another one from a junk yard. Maybe they were both be bad I guess what im asking do I need a oem main relay for like 50 buck's? Is buying a cheap main relay or a used main relay a hit and miss deal ? Thank
Old Sep 18, 2015 | 12:01 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: Main Relay for a 93 del sol m/t
I wouldn't think it would be that bad, but if you can loop the wires and have it run then you can reasonably argue the problem does lie within the relay(s). Have you tried to resolder the original OEM relay? And have you tried doing the test procedures on all 3 to make sure all 3 relays actually function as they should?
Old Sep 18, 2015 | 12:39 PM
NotARaCist's Avatar
I never narc'd on nobody!
<p>Or the pigtail that plugs into the relay is damaged. &nbsp;Inspect that connector.</p>
Old Sep 18, 2015 | 01:42 PM
I tried to re solder the the original main relay but I fried it. And burnt up the ecu too due to a bad soldering job. Ill leave that to the experts lol I tried testing the main relays and they both work. The one I bought from a junkyard and the one I bought off ebay. Both click when turning the key to the on position.So im thinking I might need a oem main relay for 50$ instead of that cheap 17 dollar one
Old Sep 18, 2015 | 01:47 PM
Originally Posted by NotARaCist
Or the pigtail that plugs into the relay is damaged. Inspect that connector.
Ill try that tonight to see if i see anything unusual I just hope i don't have to tear the dash out and and do some rewiring
Old Sep 18, 2015 | 01:48 PM
NotARaCist's Avatar
<p>Or your bad solder job fucked something else up...</p>
Old Sep 18, 2015 | 01:49 PM
24TEN's Avatar
PHANTOM MENACE
It would be worthwhile to verify the wiring from the plug then as suggested before you spend any more money. If the relays test out to be working then they should work.
Old Sep 18, 2015 | 03:39 PM
Got it working now my brother went to auto zone and got a universal main relay without me knowing it.To my surprise I tried it and it worked I hear fuel pump priming and it start's perfect now.Plus I have a lifetime warranty on this relay. Once again thanks guys for your help
Old Sep 18, 2015 | 07:59 PM
24TEN's Avatar
PHANTOM MENACE
Nice!!
turbocivic1984
Jun 29, 2008 09:59 AM
broken crx
Aug 1, 2006 03:02 AM
SOHCwarrior
Jul 4, 2005 05:40 PM
poundedhatchcrap
19
Jun 22, 2005 05:53 PM
