Ls vtec conversion question
Old Sep 16, 2015 | 07:01 PM
thugsbryan's Avatar
Default Ls vtec conversion question
When putting a b16 head on a ls block is there a oil hole that needs to be blocked out on the block and if it's not blocked out what will happen?
Old Sep 17, 2015 | 07:41 AM
turbohatch96y7's Avatar
The hole you need to plug is in the head. You tap it and plug it.
If you dont you wont have any oil pressure for the vtec system to engage
Old Sep 17, 2015 | 07:45 AM
thugsbryan's Avatar
Default Re: Ls vtec conversion question
That's d hole for the oil line feed from the block to the head you're talking right. But isn't there a hole dat needs to be plugged on the block itself?
Old Sep 17, 2015 | 08:12 AM
Vtec blocks have a oil passage for the head in the block
Non vtec blocks do not have this passage
Thats why vtec heads need that hole tapped and plugged.
Also when doing a vtec conversion There is a line that goes to the side of the head that feeds the vtec system
Dont make it more complicated then what it is
Old Sep 17, 2015 | 08:29 AM
thugsbryan's Avatar
Ok why asked is cause I recently did a ls vtec build and i see alot of oil leaking from between the head and d block and the mechanic says he torqued the head down properly so I don't know where that oil coming from
Old Sep 17, 2015 | 08:57 AM
If he didnt plug the head or use teflon then it would be coming from there
Old Sep 17, 2015 | 09:06 AM
thugsbryan's Avatar
That's what I was thinking too
Old Sep 17, 2015 | 04:58 PM
TheShodan's Avatar
Moderator
Everything you need to know about the LS VTEC
enjoy
Old Sep 17, 2015 | 05:00 PM
thugsbryan's Avatar
Originally Posted by TheShodan
tanks
Turbocivic94
Apr 14, 2009 03:38 PM
poorman's type-r
Jul 28, 2006 04:10 PM
Mr.DC2TurBo
Feb 16, 2005 12:57 PM
jackal99a
Aug 13, 2004 08:07 PM
Trooper
Nov 17, 2003 07:25 PM
