PA FS: Sloppymechanics built 1994 Civic EX Turbo
Details are in this thread
https://honda-tech.com/introduce-you...rbo-d-3256631/
hondata s300 ready ecu w/boost control
525cc FI injectors
eagle rods
vitara pistons 75mm
arp head studs
Honda head gasket top end set
D16 ebay turbo kit
walbro 255lph in tank fuel pump
stage 3 2300lb clutch off ebay
aem uego wideband
boost guage
new master cylinder/brake flush
ngk spark plugs
mbc
stock dyno
turbo dyno @22psi
Vin is 2HGEJ1130RH539472
Around 222k on the chassis, gauge cluster was swapped and shows around 135k. Motor is completely fresh (see pictures)
Have a little over $5000 in it as it sits. Running open downpipe, needs passenger side front lower control arm bushings and an alignment. I have 2 complete sets of wheels, the steelies and the other rims on the rear. Call or text Josh 484-896-8111. Looking for $4200
525cc FI injectors
eagle rods
vitara pistons 75mm
arp head studs
D16 ebay turbo kit
aem uego wideband
boost guage
ngk spark plugs
mbc
stock dyno
turbo dyno @22psi
Please see here: Honda-Tech - Announcements in Forum : Honda-Tech Marketplace
