Running P72 ECU on b20b?
I have a 1992 Acura integra with a b20b swap. The guy before me had it running a chipped p72 ECU. I recently ran into a problem where the 10A ECU fuse would blow and cause the car not to start, so I used a 20A to see if that would work so I could get home and it did. So I changed the ECU to the stock PR4. Would any problems have been made from running that P72? I heard that running a P72 on a b20b will run j to problems, doesn't anyone know if any permanent damage to anything could have been made?
Shouldn't have anything to do with blowing fuses, you have something shorted somewhere if it did. Should throw a code or two unless it was chipped specifically for the non vtec motor.
Putting larger than rated fuses in circuits is not a fix btw, just a fast way to destroy electronics and/or wiring. Pretty sure the ecu circuit is 15A though.
Well it definitely was the source of the fuse blowing because I changed the ECU to the PR4 and it is fine now with the 10A fuse on there. And on the diagram it definitely says 10A for the ECU.
If it's a stock ecu, a P75 or a PR4 with a fuel pressure adjustment will make do. Alternatively, you can probably move your chip over to the replacement ecu.
I've yet to see an ecu fail in a way that shorts it out, but I stand corrected. I'd still go over your wiring (especially in that area) and make sure you don't have something else going on.
The best ecu would be one mapped for your b20b motor from a reputable business. The p75 ecu with a higher fuel pressure will work but it's more of a "bandaid" fix.
If you can put a different ecu in the car without blowing the fuse I would lean towards the ecu being faulty. Like I said in my previous post, I have personally seen this before but it is a rare occasion.
