Coilover causing scraping sound when turning right
So I recently swapped out my pos ebay coilovers for some Tein flex Z coilovers. Everything is fine except for my front drivers side which makes a scraping sound when I turn right. Doesn't matter if I'm going 3mph or 35. It sounds like something scraping metal.
I thought maybe I just had the car to low so I raised it and now it's two inches higher than it was with my old coilovers. I double checked to make sure everything was tightened down properly. My car is not cambered, the wheel looks perfectly straight, and I don't think the wheels is rubbing on the frame cuz I can fit half my hand in the wheel gap.
Anyone know what could causing this and how to fix it?
Check brake dust shield to rotor clearance. I have to re-bend mine almost every time I take a wheel off just because I bend it without realizing what I've done.
Cool Cool Island Breezes. BOY-EE
The spring and shock on that year civic don't turn with the wheels. So it's likely totally unrelated to the coilover. A brake dust shield scraping the rotor would be a safe bet.
I meant to tell you all, it was a bent brake dust shield that was causing the problem. I guess I was stuck on the coilover since that's what I replaced and I'd never had this problem before. Who knows how long it would have taken me to figure it out. Thank you all for your help, I really appreciate it.
1991EM1
Suspension & Brakes
37
Nov 16, 2011 04:10 AM
1991EM1
Nov 14, 2011 08:33 AM
Fuster_Cluck
11
Jul 26, 2003 08:23 AM
