Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Speedometer stays at 0 mph-2004 Civic LX
Old Sep 13, 2015 | 02:43 PM
Rick hybrid's Avatar
Default Speedometer stays at 0 mph-2004 Civic LX
The speedometer stays at 0 mph. All the other gauges and lights work. i cleaned the battery terminals. any other ideas ? 147,300 miles.
Old Sep 13, 2015 | 03:22 PM
It Wasn't Me's Avatar
Default Re: Speedometer stays at 0 mph-2004 Civic LX
Try the following: https://honda-tech.com/honda-civic-2.../#post50216867
Is your MIL on? Any codes for the VSS?
Old Sep 19, 2015 | 10:49 AM
The mil blinks a few times after starting the engine but does not stay on.
I found the VSS and took it out, sprayed some brake cleaner on the electrical contacts and reinstalled it.
Son says the speedometer works once in awhile but most of the time it remains at zero.
Old Oct 25, 2015 | 07:02 PM
the speedometer was working once in a awhile. The mil was not on. any codes were cleared when i disconnected the battery. All the other gauges work fine.
I replaced the VSS and the speedometer still down not work. Looks like i wasted $75.
Is there a separate fuse for the speedometer that I should have checked?
Do I need to replace the entire instrument cluster or just part of it?
or should I be checking something else?
Old Oct 27, 2015 | 01:17 PM
Former User's Avatar
Did you run the self diagnostic test for the cluster?
Old Nov 8, 2015 | 02:17 PM
I checked the fuses. They were ok.
I ran the test twice. Both times the tach, temp and fuel gauge moved steadily to the top and then back down. Speedometer did not move.
I removed the instrument cluster and unplugged the 2 connections. Plugged the 2 connections and reinstalled it. No change, speedometer still does not work.
What next?
Old Nov 8, 2015 | 03:02 PM
Old Nov 8, 2015 | 04:49 PM
What next?
Old Nov 8, 2015 | 06:23 PM
You need a new cluster.
sh!ft
Feb 2, 2010 08:12 PM
96 EX
30
Sep 8, 2009 09:22 AM
Silver89crx
Jan 31, 2009 11:10 AM
r0n3l
Mar 2, 2006 09:48 PM
