Alternator
Ok so I just put a new alternator in my car, new battery, and it ran for about a day and now the alternator isn't kicking in its completely shot again we took the positive connection off of the battery while it was on and it died and the alternator didn't kick in. Any ideas? Need some help pleasse
Edit Reply
Edit Reply
Edit Reply
Edit Reply
Charging light isn't coming on, we tested the voltage with the car on and the battery in and it was at like 13 ish and then we disconnected the positive charge to the battery so the car would just be running on the alternator and it dropped to like 11.5 then the car died.
Cool the car down completely. Start the car up so it's idling at around 1500+- 200. Turn the headlights on and check how much voltage you are putting out.
Warm the car completely up. Turn the headlights on and idle the car. Idle should be 800 or so. Check for voltage. Push the gas until you get about 2000 rpms. Hold it there and have someone check for voltage.
Post your results.
Post your results.
89edcivic
Sep 26, 2009 02:38 PM
Lissav
Feb 2, 2008 03:58 PM
