ls turbo bogging problem
Got a 2001 integra ls turbo charged. Recently bought the car with the kit installed already. Was told there is a bogging problem. Bogs right about 4k rpm, then boost kicks in and bogs again at 6k rpm. Any thoughts on what is causing to bog?
Not tuned yet. Car seems to be running fine to me besides the bogging. Maybe it needs bigger injectors or aftermarket fuel pump. Thanks for the tips. I'll have to check them out.
You say it seems to be running fine? But it bogs at 4k and then 6K..
What ecu are you running this engine with??
What injectors? stock?
If its not tuned thats your MAIN problem, get yourself a aftermarket EMS to tune the engine if you don't already have one. You will need a aftermarket fuel pump and injectors at the very least. Take it to a good tuner and dyno tune the engine before it blows.
Sooo you have a N.A engine with a aftermarket turbo system installed on it and its not tuned and your still wondering why it doesn't run right?
Buying into a problematic turbo normally N.A motor is learning things the hard way. You'll have to learn fast.
God knows what ecu you have and what bs tune it has.
There's tons and tons online to read and learn.
Check your fule system and see what ecu you have.
It needs a good tune. No online turbo ready bs.
I guess you have a point here. I was just trying to pin point the problem. Car seems to run and drive fine if i don't beat on the car. But from your guys info, I might have more than one problem here. I was told the ECU was set up for turbo. Will have to take a step at a time
Take it to a tuner and have him take a look.
it probs has a mugen power chip y0 rare and jay de em as ****, even a basemap from a reputable tuner isn't meant to go driving the car around on merely to get it from your house/shop to the dyno that's it.
bluedragon
Oct 29, 2016 03:38 PM
GsrIntegra789
Jun 14, 2008 09:14 AM
