Headlight problems
2002 Honda Civic EX Coupe with 97k miles on it.
So I recently just replaced both my headlights because the headlight on the passenger side went out. It was fine for a day but then the following night I noticed the driver side headlight went out. I took the bulb out and put it back in but that did not work. The headlight only works when I turn the high beams on. Has anyone else encountered this?
Theyre a dual filament bulb, the lowbeam filament has likely burned off, just to be sure, try swapping bulbs from one side to the other. if the same bulb still doesnt work then its the bulb and not the connection to that headlight.
