'98 LX - A/C not working
Old Sep 5, 2015 | 07:35 PM
socialistic's Avatar
Default '98 LX - A/C not working
Just finished up swapping a y7 from a '99 in to this '98 due to bad block. Runs and drives great, the only CEL is for the missing #2 o2 sensor.
We hooked it up to the a/c machine and filled it up to spec(google said 1.4375lb so we put in 1.44lb) and while we could see the compressor kicking on and off with the a/c button, the temperature of the outgoing air in the cabin was not dropping at all. We even overfilled it a bit more, still no change in air temperature.
What all should I be checking?
Old Sep 5, 2015 | 08:00 PM
Former User's Avatar
Default Re: '98 LX - A/C not working
More background is needed. How do you know the system was low or out of refrigerant?
Old Sep 5, 2015 | 08:24 PM
Both this car and the '99 parts car had their systems drained by the recycler(this wheeled machine with a pump, tank, some gauges, hoses, etc) prior to the tear downs/swap. I swapped over the engine only. Once the '98 was put back together we filled it up to spec(23oz/1.44~ lb according to google). It held pressure, but wouldn't blow cold even though the compressor appeared to kick on and off with the button.
Could the compressor still be bad? I have the one from the '99 that has 100k less miles but ran out of time and had to get home so I couldn't swap them out.
Old Sep 5, 2015 | 08:27 PM
Did the A/C work prior to recovery of refrigerant?
Was the system opened to the atmosphere after recovery?
Was the system placed under a deep vacuum prior to recharging with refrigerant?
Does the condenser fan run?
Old Sep 5, 2015 | 08:31 PM
No idea, block was all sorts of grenaded so I never tested it.
Yes, for the swap. Detached hoses at front of motor so compressor could move with engine.
I honestly don't know, didn't check but I brought the car home finally and it is still full so I can check tomorrow.
Old Sep 5, 2015 | 08:32 PM
Old Sep 5, 2015 | 08:34 PM
Yes, he did put the system under vacuum prior to filling. We even recovered, vacuum, filled a second time just to rule out an issue with the first.
Old Sep 5, 2015 | 08:35 PM
Was the receiver/dryer replaced prior to recharging?
Old Sep 5, 2015 | 08:36 PM
Nope.
Old Sep 5, 2015 | 08:37 PM
Was the system recharged with both oil and refrigerant?
Old Sep 5, 2015 | 08:39 PM
I'm not sure. I'm leaning towards no oil on the recharges.
Old Sep 5, 2015 | 08:41 PM
Were any A/C components removed and replaced?
Old Sep 5, 2015 | 08:43 PM
The compressor was pulled from the engine for a short time in order to access that engine mount, other than that nothing else was touched as far as climate system goes.
Old Sep 5, 2015 | 08:44 PM
Any oil lost from compressor during removal or reinstallation?
Old Sep 5, 2015 | 08:46 PM
Honestly not sure. The hoses were left attached to it and I don't recall anything dripping from them, and it was only for a short time. Total time for hoses not being connected to a vehicle's system was maybe 30 minutes.
Old Sep 5, 2015 | 08:51 PM
Recover refrigerant and oil again.
Replace receiver/dryer.
Place system under deep vacuum for at least 30 minutes.
Properly recharge with refrigerant and oil removed by recovery.
Check whether compressor clutch engages and fan runs when A/C is on.
If so, performance test system (high and low side pressures; vent temp; ambient temp and humidity) with engine held at 1500 rpm and A/C running at max.
Old Sep 6, 2015 | 06:46 AM
I'm running to autozone to pick up a few things and they do have a receiver/dryer in stock for $22~ so I'll go ahead and grab that. I'll either swing the cost to have a local shop look in to it for me, or I'll continue troubleshooting next weekend at my buddy's shop.
I can test the fan today. Will report back if I do.
Thanks for all the info!
k1sm3t
Honda CR-V & Element
12
Nov 8, 2014 03:40 AM
sk8board{Pete}
Jan 31, 2009 07:30 AM
T-RO
May 16, 2006 05:26 AM
Capt. Jimbo McSubipants
Aug 31, 2005 12:01 AM
