95 hatch. Crank, No Start
Old Sep 5, 2015 | 04:37 AM
b20bubble's Avatar
Default 95 hatch. Crank, No Start
1995 hatch
B20b
Edelbrock IM & TB
AEM Fuel Filter w/ Gauge
STOCK: Fuel Pump, Injectors, FPR, p75 ecu.
Also new fuel filter, drained tank with fresh 93 octane.
Car ran fine for 2 years. Wouldn't start on my way home from work one day, Cruise Control light was on, Many threads said this was due to a dead chipped ecu. Swapped in stock injectors and ecu, Cruise light went away. Still no start. Compression test revealed a dead cylinder. Swapped another B20, Same issue.
Car will crank, has spark, 40+ psi @ fuel gauge, good compression (140-150 across the board), Noid test on injectors, they all flash. It will start up for about half a second sometimes and just die out.
Just looking for some insight before I part this thing out.
Sensors I'm over looking? Car was modded by PO.
CEL light works, I'm getting no codes.
I've tried 2 p75 ecu's, a p28, 2 sets of stock injectors and a chipped p28 for 310's with brand new 310 injectors.
Old Sep 5, 2015 | 06:01 AM
Former User's Avatar
Default Re: 95 hatch. Crank, No Start
Will the engine start with starting fluid?
Is spark bright white?
Old Sep 5, 2015 | 06:08 AM
b20bubble's Avatar
Yes, it starts with a spray of starting fluid in the TB.
Sparked seemed decent, it was outside when I checked it, so I can't be sure it was BRIGHT white as i couldn't get the best view from inside the car.
Old Sep 5, 2015 | 06:12 AM
Sounds like the fuel injectors are not receiving ground pulses from the ECU.
Old Sep 5, 2015 | 07:33 AM
b20bubble's Avatar
Old Sep 5, 2015 | 07:34 AM
I agree.
Old Sep 5, 2015 | 07:38 AM
b20bubble's Avatar
Noid light shows pulse @ injector clips
Old Sep 5, 2015 | 07:41 AM
Do the injectors pulse fuel?
Old Sep 5, 2015 | 07:45 AM
b20bubble's Avatar
What would be the best way to test this? Pull each spark plug to see if damp?
Old Sep 5, 2015 | 08:27 AM
You can remove the fuel rail and have a friend briefly crank the engine while you hold the injectors in place. Look for fuel spray from each injector. This is a "no smoking allowed" test.
Old Sep 5, 2015 | 10:13 AM
b20bubble's Avatar
I'll try to get someone to help me out tomorrow with this.
Old Sep 28, 2015 | 06:19 AM
b20bubble's Avatar
Finally got back over to the garage.
Ziptied the injectors and pulled em. All 4 injectors spray with their corresponding plugs hooked up.
Old Sep 28, 2015 | 07:13 AM
This^ clearly indicates a fuel problem.
Check whether the injector clips are installed in the correct firing order.
Old Sep 28, 2015 | 08:09 AM
b20bubble's Avatar
Yes, but what?
I can't figure it out.
Checked them 3 times.
Old Sep 28, 2015 | 08:10 AM
b20bubble's Avatar
Also, not sure if related, sometimes when I go to crank it over, I hear a loud click and have no power. have to pull the battery cables off and reattach them.
Old Sep 28, 2015 | 10:19 AM
Again, if correct, this^ clearly indicates a fuel problem.
Old Sep 30, 2015 | 10:31 PM
b20bubble's Avatar
I've tried 2 sets of factory injectors. I don't believe those to be the issue.
Other than the ecu, is their anything else that controls the injectors?
Old Oct 1, 2015 | 12:41 AM
tony_2018's Avatar
Fish Twig
It doesn't make sense that your car starts with start fluid, but not with your fuel injectors. Does that make sense to you?
Old Oct 1, 2015 | 01:40 AM
b20bubble's Avatar
Not at all.
anon191
17
Jun 25, 2013 10:33 AM
b20c
Apr 14, 2010 09:08 AM
LaXcAt
Jan 8, 2008 07:22 AM
builtboostedteg
Jul 29, 2005 02:47 AM
jesse d
Aug 6, 2004 06:19 PM
