how to reduce torque steer
If, your car doesn't already have them you might want to consider 70 or 80 durometer polyurethane for your transmission and rear engine mounts. Should help keep to the wheels planted and reduce torque steer. however, the side effect will be increased engine/car vibration.
9500 rpm's...when does the rev limiter kick in?
OP: equal length drive axles help to even the distribution of torque to each wheel as does an LSD as NotARaCist mentioned. you may also want to limit the forward movement of the front LCA under load to reduce it's effects as much as possible.(the drive force from the wheels pulls forward at the lower ball joint, this tries to pivot the LCA around the front bushing. the rear bushing does it's best to resist). stiffer rear LCA bushings would be a good step one. adding a "traction bar" would be even more effective at reducing this movement.
buy a traction bar for a few hundo. problem f***ing solved.
This one, buy this one. and never ask about this ever again.
http://www.full-race.com/store/tract...ction-bar.html
These are good reads: Torque Steer: Causes and Cures and http://www.ehow.com/how_8784078_fix-torque-steer.html
triple
14
Nov 22, 2005 10:11 AM
