Bushing Kit
Old Sep 2, 2015 | 05:18 AM
angrysmileyface's Avatar
Default Bushing Kit
I know there is a hardrace kit for the 5th/6th Gen Civics as well as the Integras, but is there a full bushing kit of any sort for the 5th Gen Accords? I do not want Prothane or Energy bushings (I really dont want anything eurethane). Trying to go as inexpensive as possible *but not cheap* All help is appreciated. Thanks
Old Sep 2, 2015 | 07:51 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Bushing Kit
HARDRACE GLOBAL
Did you look? Quite a bit comes up...
Old Sep 2, 2015 | 09:12 AM
Actually I did look, hence my question. For a 5thgen Civic or 6thGen Civic they have a kit of 26 or so pieces ie a semi-Master kit. I am looking for the same for the 5thGen Accord.
Old Sep 2, 2015 | 10:23 AM
MAD_MIKE's Avatar
MM Gruppe B
They do not have a kit, but they have all the bushings needed to tighten up your suspension, less the sway bar bits.
Old Sep 2, 2015 | 10:59 AM
So we're too lazy to manually add the parts into the cart? All the kit's done is lumped them together...why are you not just adding all the parts individually?
Rear Upper - 2pc
Rear Lateral - 8pc
Rear Trailing - 2pc
Front Upper - 4pc
Front Lower - 4pc
Rear Shock - 2pc
That wasn't too hard, was it? All 22 piece "set"
And I'm not trying to be a dick, but you're asking for a set of Hardrace bushings, they exist, they're sold from the same store, and you just want to buy a single SKU rather than each individually? Seems like a silly reason to not buy them.
Old Sep 3, 2015 | 03:43 AM
The concept of the set isnt important, its more the fact that I can shop around for a single set to find a good price. When I did the civic, I spent several months looking for a good price on the hardrace since pic at the time was no longer carrying the full set. In this case, it doesnt even have to be a set of hardrace, it could be pic (if they have something) or some other quality maker of rubber bushings.
Old Sep 3, 2015 | 08:01 AM
So I'm aware of:
Energy Suspension (you've said no)
Prothane (you've said no)
Hardrace (linked above, you want a single kit for whatever reason)
SuperPro (this is for a CB and not a full kit)
Beyond those, I don't think you're going to find any halfway decent bushings...
If it's any other aftermarket company that offers them (like FatFourCustoms) they usually use one of the above and just rebrand it.
There's also PowerFlex, but they don't make it for an Accord.
Old Sep 3, 2015 | 12:34 PM
I appreciate the info. Thank you.
Kelly66218
Nov 11, 2010 01:10 AM
97ludedude
Jun 24, 2008 09:41 PM
civicboy95
May 21, 2002 12:40 AM
