Which parts help bring the power of your motor to your wheels?
Old Aug 31, 2015 | 03:38 AM
Krispyrocket's Avatar
Default Which parts help bring the power of your motor to your wheels?
Besides tires and LSD, what else will help deliver more hp to your wheels?
There's always a saying that whatever your hp is rated at, only 80-85% is being applied at the wheels.
Old Aug 31, 2015 | 08:15 AM
m4xwellmurd3r's Avatar
LSD and tires don't increase power to the wheels.
They say that due to frictional losses on the drivetrain
Have you ever turned the input shaft of a transmission? It takes some effort to do so. All the heard meshing, and all the bearings from the transmission to the hubs, and even the angle on the axle joints cause frictional losses.
Old Aug 31, 2015 | 10:32 AM
Default Re: Which parts help bring the power of your motor to your wheels?
Bump.
Old Aug 31, 2015 | 04:19 PM
VegaS10's Avatar
Your question was answered, why bump the thread?
Old Sep 1, 2015 | 10:11 AM
To see if anyone else has any other ideas. No need to be hostile. I do believe that lsd and new tires helps maintain the power. Without lsd and bald tires, what scenario would that be?
Old Sep 2, 2015 | 03:35 AM
rudebwoy's Avatar
Nothing!
turn up the boost.
Old Sep 2, 2015 | 08:13 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Direct Drive - So you better convert to RWD and have a push start vehicle for all those stoplights.
You can cut down on some rotational losses with good fluid and coatings. Your gains will be minimal.
Old Sep 2, 2015 | 12:17 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Your approach is all wrong...
Mechanical powertrains, consisting of engines, transmissions and driveshafts or axles will all have some power loss from flywheel to tires. You need to attack this in the other direction. Instead of working on improving the percentage loss of your current powertrain, focus on making MORE POWER. The loss is relative. As stated above, you will get miniscule gains from slicker fluids, metal gear treatments inside the transmission, and friction materials that will "slip" less between the flywheel and input shaft... and the expense will be great for most of these.
Just make more power and don't worry about what little is lost.
Old Sep 2, 2015 | 05:24 PM
Jrcivic is right. But it would be nice to change out the stock joints and stuff before hopping onto the internals of the motor.
Old Sep 3, 2015 | 08:28 AM
spAdam's Avatar
Loved
Community Favorite
Yeah but there isn't really much meat on that bone. If everything is working correctly, these drive trains are pretty damn efficient.
Replace all bearings, make sure all of your gears are in good shape and the trans is assembled correctly... It is probably a 20 year old car we're talking about anyway... That's about all you can do. Then go make more power
Old Sep 3, 2015 | 03:31 PM
Lmao 22 to be exact.
kidwit93delsol
Mar 8, 2008 10:16 PM
keegur
Mar 28, 2007 02:52 PM
93Ludevtech
Dec 15, 2005 06:20 PM
turbohappy
20
Sep 28, 2004 08:00 AM
unknown0001
May 26, 2004 12:07 PM
