Suspension & Brakes Theory, alignment, spring rates....
15x8 +20 offset
Old Aug 30, 2015 | 12:50 AM
2kdrift's Avatar
Default 15x8 +20 offset
Tried searching but cant to seem to find a good answer as most users are dropped my car has no drop at all
I need to get some new rims / tire set up for my turbo build.
Im looking at 15x8 +20 rims if i can run a 205 tire that would be great. Possibly go with 195
+20 is the highest offset I have found in the style I am looking at.
any recommendations as far as clearance with that amount of offset whats the widest tire I can run?
98 CIVIC HX
Old Aug 31, 2015 | 01:35 PM
2kdrift's Avatar
Default Re: 15x8 +20 offset
Originally Posted by solbrothers
you don't need new rims for your turbo build
Thanks for the reply but I do WANT wider tires for the added traction. i believe I am running 185's right now, On my current rims so Im not to sure if it would to be able to take a 205
Old Aug 31, 2015 | 01:45 PM
theYBLEGAL's Avatar
Loved
Not sure a 20 offset is enough. Thinkin you'll rub inners?
Probably +30-35
Old Aug 31, 2015 | 02:43 PM
2kdrift's Avatar
Probably +30-35
Thanks I think your right.....Not sure the width of my current rims but I believe the offset is probably closer to the correct offset. Hopefully the wider tire will work on my current rims
Old Aug 31, 2015 | 03:37 PM
theYBLEGAL's Avatar
Loved
I think 15x7 +35 is biggest you can go, while low, without stance and or rolling fenders.
Thats what i'm looking for at least. 00 ej8
Old Aug 31, 2015 | 07:45 PM
2kdrift's Avatar
I am not dropped but I might want a small drop in the future for suspension performance. Would be nice to have that option, I can roll fenders if needed. Kinda sux I cant find the specs of my current rims. I would guess they are 15x7 +35 but Im a complete noob when it comes to rims I was never into stance or anything just looking for improved traction.
brand is HAVOC I have heard they are ROTA knock offs
Old Sep 11, 2015 | 01:46 AM
Wannabe JDM's Avatar
oh snap.... knock off of knock offs hahha.
Old Sep 11, 2015 | 05:37 AM
m4xwellmurd3r's Avatar
I have stock 15in Honda steels. 205/50-r15's fit perfect. You don't need fancy rims for a 205. Cheapo 15in Honda steels not only fit the car perfectly, but fit a 205/50 perfectly.
Old Nov 4, 2015 | 02:31 PM
DA9nEF9's Avatar
I wouldn't worry so much about tire width, rather tire compound. a 185 extreme performance tire is going to provide more traction than a 205 summer tire. You could fit the 15x8s but you would need fender rolling and possibly a little pulling.
Old Nov 6, 2015 | 12:19 AM
.Grimace's Avatar
footwork mastery
If you get a 15x8 run a 205 smallest or preferably a 225. A 195 is meant for a 15x7
NewtoCivics
Mar 25, 2012 05:39 PM
willu707
Jan 24, 2009 09:59 AM
civicz
Aug 12, 2007 01:03 PM
S2k Hybrid
Honda S2000
Jun 12, 2006 06:46 AM
Todd00
Dec 5, 2001 11:59 PM
