Tig Rod Size for Aluminum Sheet
Old Aug 29, 2015 | 11:38 PM
TracerAcer2.2L's Avatar
Anti-GDD White Knight Simp
Default Tig Rod Size for Aluminum Sheet
I'm wanting to make a sheet metal intake plenum, think it will be a fun project to practice on. I'm looking at using .1" (2.5mm) T6 sheet, but I don't know if I should use 3/32 rod or 1/8
Literally all the info I need I found on Miller's website except for this. After a good search elsewhere I remembered my Honda brethren could probably help, thanks for any advice
Old Aug 30, 2015 | 09:41 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Tig Rod Size for Aluminum Sheet
1/16" or 3/32" filler. Depends on joint. Also, it is on their website...
Miller - TIG Welding Calculator
Old Aug 30, 2015 | 05:08 PM
Thanks! I actually saw the tig calculator link on a page and clicked it, but it took me to a different page...weird
Old Aug 31, 2015 | 03:07 PM
aluthman's Avatar
I used 0.100" 6061 aluminum for the meth tank I built for my car and 3/32" 4043 rod worked beautifully. 1/16" probably would have also worked fine, but you would have to cram it in faster. I think ⅛" would probably be way to big, although I haven't tried it.
Old Aug 31, 2015 | 05:53 PM
Aluthman, I think I actually saw that going back over 98vtec's thread after I posted this, those were some great welds. I ended up buying 4943 in 3/32", apparently 4943 welds even better than 4043
Old Sep 2, 2015 | 09:02 AM
SovXietday's Avatar
I have found that aluminum is a lot more forgiving for the filler rod size than steel is regarding puddle feel.
That said, I would go with 3/32. The amount of heat you're going to want to put into a .1" wall plate will probably give you issues with melting the filler rod in front of the puddle with 1/16"
Old Sep 2, 2015 | 10:24 PM
v8killaz's Avatar
I honestly have used 3/32 for everything from 1/16 alum to 1" alum.
Old Sep 18, 2015 | 10:44 AM
bks84's Avatar
Loved
i typically use 3/32 for most everything.
Justin Olson
Welding / Fabrication
Aug 31, 2007 06:30 PM
VTIDelSol
May 4, 2005 02:49 PM
SiRex91
16
Mar 21, 2005 10:22 AM
.RTErnie
30
Dec 20, 2004 04:07 PM
rocket_R
May 1, 2003 06:41 AM
