Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
transmission sounds and jerking
Old Aug 28, 2015 | 03:22 PM
cag022's Avatar
Default transmission sounds and jerking
I got a 2013 civic SI coupe and for a while... I thought it was the smoothest manual transmission I have ever driven. Maybe about a couple of months ago, I started hearing the change of gears every time I shifted. It use to be fairly quite but now it seems it is getting louder and louder to the point that even with the radio on, I can hear the sound every time I shift (usually happens in the lower gears. 1,2,3)
That is not the biggest issue though. The shifting from 1 to 2 has some major jerking. The moment that I release the clutch and step on the gas, no matter how subtle I try to be in the transition, it feels as though some one rear ended me. In addition, every time I drive in second gear (and it only happens in second and first gear) and then take my foot off the gas the same level of jerking occurs...maybe even a bit more.
This is not how it use to drive. Has anybody experienced this or has any suggestions as to what it could be? Any information is helpful!
Old Aug 30, 2015 | 09:21 AM
97emsedan's Avatar
Default Re: transmission sounds and jerking
Change your transmission oil to a synthetic like Amsoil. It smooths out the shift somewhat and kills the shift noise. As for the bucking, are you dumping the clutch? I can't think of a way to dampen that symptom.
cag022
Transmission & Drivetrain
Sep 7, 2015 12:42 AM
nice_tan
Aug 25, 2015 11:07 AM
vroomboom
Honda Civic (2001 - 2005)
37
Jun 5, 2008 07:54 PM
1Cloudwalker1
Jul 17, 2005 04:35 PM
xcom
Sep 29, 2004 12:56 PM
