95 Civic - code 23 or codes 20 and 3?
Old Aug 27, 2015 | 01:42 PM
EJ1Shifty's Avatar
Default 95 Civic - code 23 or codes 20 and 3?
So I have a 95 civic coupe ex bone stock d16z6 virgin p28 ecu. While driving for about 10-15min my cel will come on (car runs fine) I pulled codes using paper clip method cause it is obd1 and pulled codes 23 (2 long flashes and 3 fast right after no pause.) I've been told many different things I've been told it could be my O2 sensor and cat converter giving me problems also have been told it's code 20 (wiring issues) and code 3( MAP sensor) recently since yesterday the car has turned off on me twice once yesterday and once today while in N cruising to a light. I turned the car back on without a problem the CEL would go away then come right back code 23 is referred as knock sensor but I've been told d16z6s don't come with this nor does the p28 so I'm unsure as to what the problem is any help would be appreciated I have reset ecu for the light to go away but just comes back on while driving( SIDENOTE: while driving and CEL is on I'll hit a pot hole (unintentionally) and it'll hiccup then the CEL will go away then come right back) any help would help as this is my daily for work and school
Old Aug 27, 2015 | 02:38 PM
Neth's Avatar
Default re: 95 Civic - code 23 or codes 20 and 3?
easiest way to confirm the codes is to take a video of the CEL and post it.
also, pretty sure you have a knock sensor located on the backside of the engine above the oil filter, you can follow that wire and make sure it's plugged in and not broken anywhere.
Old Aug 27, 2015 | 03:59 PM
EJ1Shifty's Avatar
I was told they don't also looked it up saw people install their own for boost. Idk why it would turn on motor isn't knocking runs perfectly fine I'll post a link to the video
Old Aug 27, 2015 | 04:01 PM
EJ1Shifty's Avatar
Old Aug 28, 2015 | 02:28 AM
HondaPartsHero's Avatar
Technical Hero
Thats 23 and you shouldn't be throwing that with a P28 as its for knock sensor.
Old Aug 28, 2015 | 03:06 AM
NotARaCist's Avatar
I never narc'd on nobody!
<p>
</p><p>This. &nbsp;Check your ECU sticker to make sure you actually have a P28. &nbsp;If you do, open it up, take a picture, and post that picture.</p>
Old Aug 28, 2015 | 05:48 AM
Former User's Avatar
Default Re: 95 Civic - code 23 or codes 20 and 3?
Chipped P28?
Old Aug 28, 2015 | 10:20 AM
NotARaCist's Avatar
<p>Or someone added a knock board (if that's even possible, I don't know, just a thought).</p>
Old Aug 28, 2015 | 04:58 PM
EJ1Shifty's Avatar
Haven't gotten the chance to open it up yet pretty sure it's virgin but once I do I'll post pics
Old Aug 28, 2015 | 05:15 PM
eghatch9295's Avatar
Stancetard Hate Monger
it cant be stock, p28 doesnt "know how" to check for knock
Old Nov 20, 2018 | 08:59 AM
Albert Spicer's Avatar
89luderSi
Oct 25, 2011 10:54 AM
tonydize21
Jun 23, 2011 05:50 PM
ZCboost
Sep 21, 2010 09:49 AM
moto310
Nov 19, 2007 05:49 PM
TeknikDC2
Jan 24, 2007 06:38 AM
