low rpm
Old Aug 27, 2015 | 10:57 AM
MMB76's Avatar
Default low rpm
Hi, I own a Honda Civic EG8(1992)D15B VTEC JDM and I have a problem with rpm.
When I start the engine idle speed starts to 200-400 rpm.
It doesn't make the same all the time.
when I stop at traffic lights, idle speed drops from 700 to 400 and after the idle speed is back to normal. Pls help me.ty
Old Aug 27, 2015 | 12:02 PM
White_EG1's Avatar
Default Re: low rpm
Clean your IACV and reset the ecu.
Old Aug 27, 2015 | 12:03 PM
RoadRaceH2B's Avatar
Default Re: low rpm
Check your base timing, and make sure the timing belt hasn't jumped. I would also run a leakdown test to make sure there isn't any valve damage to start off with. Then do what the guy above me said.
Old Aug 27, 2015 | 06:26 PM
ek9_beast's Avatar
Default Re: low rpm
Iacv Iacv and Iacv first things first
Old Aug 28, 2015 | 05:28 AM
Lord Dutton's Avatar
Default Re: low rpm
I need to clean mine iacv due to high idle rpms, but what do you clean it with. Little new to this.
Old Aug 28, 2015 | 05:47 AM
ek9_beast's Avatar
Default Re: low rpm
When u pull it off the manifold u will see that it has a mesh filter. That's what you clean with carb cleaner or brake clean(anything that evaporates)
DO NOT SOAK IT by any means
Old Aug 28, 2015 | 07:25 AM
MMB76's Avatar
Default Re: low rpm
I will clean the IACV and I will answer you. ty
thewrai6th
Apr 29, 2014 12:59 PM
flood
Mar 30, 2005 08:46 AM
tommyd
Apr 29, 2003 11:02 AM
d_civic_j
Apr 21, 2003 05:39 PM
jetdriven
Jun 2, 2002 11:51 AM
