2000 EK Civic with a B18c4, where to go from here ?
Old Aug 25, 2015 | 01:34 AM
Burdsall's Avatar
Icon2 2000 EK Civic with a B18c4, where to go from here ?
Yo Guys
Im looking for some help with my car project, I work away so I get large chunks of time to work on the motor. I bought a 2000 EK Civic nice and cheap with minimal rusting and decent undercarriage. Im no car mechanic so I thought I would teach myself along the way. Before I came away last I managed to get the old motor out along with all of the brakes, PS, wiring etc. I then set out doing some research on which motor would be a good upgrade in power from the stock 1.4, after reading the forums I had the idea on a k20a2 which was soon ruled out as it was too much for a first job so I bought a B18c4. Ive seen a long list of mods than can be done to these EKs with B18c4's in them, for example the basics like a A/M intake and exhaust with stainless catback and back box with a 4-2-1 for decent low to mid range power, and a Skunk intake mani with a 70mm TB. Ive also seen some more complex modifications like the 'Poor Mans Type-R' which im still a bit fuzzy on.
My question I put out there is what are the basic improvements that can be done to see to some decent gains? I would appreciate a little description as to why you suggest what you suggest so I can continue to learn the trade.
Cheers for the help.
Old Aug 25, 2015 | 01:43 AM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: 2000 EK Civic with a B18c4, where to go from here ?
not much to be had in the gains department from bolt ons. your exhaust should be upgraded to 2.25 inch. aside from that, the only real gains you'll see is from a chipped obd-1 ecu and some dyno time.
Old Aug 25, 2015 | 01:57 AM
Burdsall's Avatar
So what will I need to do to start seeing some progress ?
Old Aug 25, 2015 | 04:21 AM
tony_2018's Avatar
Fish Twig
Finish the swap and go from there.
Old Aug 26, 2015 | 02:34 PM
bspeed's Avatar
You are in UK, yes? The Tegiwa Toda copy is a great header for the money. Some tuner cams like Skunk2 sells with uprated valve springs. ITR ecu if you are staying obd2. Drive that for a while, it will be a lot of fun.
Old Sep 1, 2015 | 02:01 AM
Burdsall's Avatar
Thanks for the reply and the idea ill have a read up no the mani and into some cam shafts. Now with the valve springs would you say go for better retainers and valves also ?
Old Sep 1, 2015 | 02:35 AM
ferio-ichi3's Avatar
Ferio Wdm Edition
Type r valves as they are lighter than stock b series valves, and can be had for cheap. Stock retainers will be just fine. No titanium retainers as they wear much faster than the oem ones.
Nfs-ek
Oct 30, 2017 07:53 PM
Mr Rattles
Appearance Build Threads
Mar 3, 2016 11:46 PM
rdt
Jun 23, 2008 06:20 AM
HaNgTiZZy
Northern California (Sales)
Dec 13, 2007 11:48 AM
civicyellow
Nov 2, 2005 01:08 AM
