97 Honda Accord Does Not Start
Old Aug 24, 2015 | 10:55 AM
Alex99's Avatar
Icon4 97 Honda Accord Does Not Start
Hello,
I am dealing with an interesting issue in which my Honda Accord will not start.
Stats: 97 honda accord
85,000 miles
4 cylinder
non-Vtec
Background: The problem started a couple months ago, as I would drive the car it would completely stall out, the gauges go to 0 but it returns to normal after a half second. This continued to happen more frequently, at the end sometimes twice in one trip. The problem progressed into times where it would shut off and would not come back on until I wiggled the key. Maybe two months ago, I tried to start my car and the car only clicked when I put the key in to the start position. One click from the solenoid. After turning the key a few times to the start position, it would role over. This began to happen more frequently. About a week ago the car refused to start. I had to put the key into the start position maybe 50 times until it finally rolled over. I am now at a place where no matter how many times I turn the key, it will not turn on.
What I have done: Replaced the ignition switch
Tested the Starter at Autozone
Attempted to jump the car (charged the battery from a 2006 Hyundai Tuscon for 4 minutes at 1500RPM)
Anything you guys can suggest would be a tremendous help, because I am at a loss. Help?
Old Aug 24, 2015 | 05:42 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 97 Honda Accord Does Not Start
Did you replace the ignition switch(electrical) or the key cylinder?
Verify all grounds and bonding jumper are installed correctly with clean/tight connections.
Verify the battery connections are clean and tight.
Verify no damage to the underhood fuse box(where the (+) cable attaches).
Verify the battery is holding a full charge.
Verify battery voltage at the ignition switch(electrical).
Old Aug 24, 2015 | 07:06 PM
Alex99's Avatar
I did change the electrical part of the ignition switch.
Thank you for the suggestions. I will grab my voltage meter and check your list of things to check.
I will post my findings.
Old Aug 24, 2015 | 07:51 PM
Alaina98civic's Avatar
My 2000 accord did the exact same thug. Turned out to be the safety neutrals switch. (In automatic) apparently it's a crappy design. I just by passes it (after spending $350 in parts I didn't need), by putting a hot wire ran to a switch under dash. Turn key, hit switch, fires right up. I have 9 Hondas and 8 of them have down this.
Old Aug 24, 2015 | 08:45 PM
Alex99's Avatar
Thank you. I thought that this might have been a possible culprit. I will add that to the list of tests and post the results.
p00fyy
Oct 22, 2016 07:14 AM
dkal24
Dec 5, 2015 05:20 AM
vetalk90
Jun 27, 2012 04:22 PM
jamielee
11
Jul 14, 2011 11:05 AM
robc737
Dec 8, 2007 10:34 AM
