Brake Pedal Play
Old Aug 24, 2015 | 09:35 AM
trailshredder's Avatar
Default Brake Pedal Play
Read in the service manual and several other references a spec for the "freeplay" on the brake pedal on my 94 Accord with very soft (to the floor) pedal. What I cannot find is if that is measured with the car off, or running. I assume running but nothing specifically says. Anyone know for sure?
Old Aug 24, 2015 | 09:49 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Brake Pedal Play
Freeplay is the amount the pedal travels before actuating the booster/mc.
If your pedal is soft then you most likely need to bleed the system.
Freeplay is the slack that needs to be taken up before the pedal actuates the brakes. Normally can be felt by a slight dip in the pedal before the brakes engage. Engine off, deplete boost assist by depressing the pedal 3-4 times, then note how much takeup there is before contact. IIRC spec is 1/16".
After adjustment verify the brake light switch is also properly adjusted.
Old Aug 24, 2015 | 11:25 AM
I have bled them till new fluid has come out all bleeders a number of times. Master cylinder replaced, No fluid is leaking. Thinking it must need adjusted.
jdm_krish
Suspension & Brakes
Apr 26, 2019 06:45 AM
dgdarien
Sep 25, 2009 06:25 PM
tylergwesterhold
Feb 7, 2009 06:11 AM
mkalisky
May 12, 2006 01:47 PM
underage
Aug 9, 2005 05:57 PM
