Transmission & Drivetrain Gearboxes, Differentials, Clutches
NEW CLUTCH INSTALLED ... first gear shakes when engaging
Old Aug 22, 2015 | 05:21 PM
carbone's Avatar
Default NEW CLUTCH INSTALLED ... first gear shakes when engaging
Installed new clutch into 98 civic ex sohc... Stock tranny stage 2 mitsuto manufacturer... When from start motor shakes when engaging... Used stock flywheel didn't replace it... What could be causing the shake in first gear a little in second... Could it be flywheel is bad could that be causing the shaking in first gear
Old Aug 24, 2015 | 03:34 PM
Runnerdown's Avatar
Default Re: NEW CLUTCH INSTALLED ... first gear shakes when engaging
Could be the flywheel surface. Could be the subpar quality dollar store clutch kit.
Old Sep 3, 2015 | 05:22 PM
carbone's Avatar
Old Sep 3, 2015 | 05:31 PM
viper_boy403's Avatar
Clutch chatter from either aggressive clutch material, or a combination of that and a non-machined flywheel surface.
Old Sep 3, 2015 | 07:29 PM
RoadRaceH2B's Avatar
It just MIGHT be that shitty clutch you're using.
For what reason did you upgrade the clutch?
Old Oct 8, 2015 | 09:18 PM
BrakeExpert's Avatar
If you don't have any major power mods, a stage 1 is plenty (our OEM clutch is a stage one Exedy-Daiken clutch - compared to other makes of cars, the D16 have a pretty sporty clutch stock.) If the car shakes and goes away after it engages, that is called clutch chatter and you can adjust your clutch pedal to help a little bit. However, changing a clutch without resurfacing your flywheel is like putting on new brake pads on an old rotor, you aren't getting full contact. Ideally its best to take it apart asap and resurface the flywheel. If you're too lazy, find a steep hill and burn your clutch on it for about 5 or 6 seconds. Rev to about 3500 and let the clutch slip till you smell it. Its a hackjob but its like fast bedding in brakes, and will help for the time being. As you continue to drive, it should get better in time.
an2ny888
Sep 7, 2010 08:58 PM
cbmprelude
11
Apr 27, 2006 08:39 AM
lude98SH
Feb 21, 2006 07:28 AM
gotalcoholmanup4
Nov 14, 2005 05:39 PM
Seann
Jan 31, 2003 02:48 AM
