factory stereo removal question
How do I remove the plastic "pocket/cavity" below the stereo on my 99 Prelude? I'm getting to perform an XM radio install and need to pull the factory head unit. Thanks.
Its not hard at all.. first remove the plastic center peice.. its mounted to your dash by clips on the inside so you will have to use a flat head screwdriver to pry it out.. (be gentle seeing as though you dont want to crack it or scratch it seeing as though you will have to put this back on and it is visible..) anyhow, once that peice is off you will see the bracket that the radio and pocket assembly is mounted on.. it is held in place by two screws.. remove those two screws and the entire radio / pocket assembly can be removed... should all be down hill from there...
actually its 4 screws that hold the whole assembly in....the top and bottom sections.
there are about 2 more screw that come from the sides that hold that bottom pocket to the frame
matt94z
Audio / Security / Video
Feb 15, 2009 10:58 AM
wilaivue
Jun 2, 2008 01:19 PM
