Sunroof problem
Old Aug 18, 2015 | 09:11 PM
Ej8_Travis's Avatar
Default Sunroof problem
My 96 civic sunroof won't open. When I press the button to open it I can hear the motor trying to open the sunroof but it won't move. To me it sounds like something is blocking it. What do you think I should check first? Thanks.
Old Aug 18, 2015 | 11:18 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: Sunroof problem
pop open the access cover and look inside
Old Aug 19, 2015 | 12:43 AM
Mugenkid's Avatar
Maybe it's the switch.. my EG had the same problem got a,new motor too and it still did it.. can you manually close it?
I took the whole thing out to see if it's blockage but saw nothing with the new motor I manually open and closed it.. It was fine
Put it back in and it worked
When I used the switch it opens and closes but the vent setting doesn't I need a new switch.. so try that first...
Pilotperson
Jul 27, 2016 05:33 PM
da1lydr1ver
Oct 8, 2007 12:30 PM
Kovatch EG
14
May 17, 2007 12:20 PM
ransack
Dec 21, 2002 05:09 PM
io_burn
14
Feb 25, 2002 05:07 PM
