accord 01 no dash parking, visor lights
Old Aug 15, 2015 | 02:58 PM
bugenz's Avatar
Default accord 01 no dash parking, visor lights
Hello,
I been reading on how to fix this issue and my mechanic himself is having a hard time. I originally switched the interior lights to led's in the doors, visors, and cabin. I went back to switch them back to the stock lights on kust the cabin and visor and when I was replacing the led on the drivers visor i noticed the stock light was not working. Then i realized my dash light was gone, and my parking lights too.
I had all the fuses checked, they are good. The ones under the hood are fine too including relays.
He went around with the volt meter and got no current from the drivers visor where the bulb goes.
He moved the relays too to see if the was the case and nothing.
Last night driving home, I realized the now the taillights are out but when I break they work. The mechnic took all the fuses under the hood and put them back adter he was done testing for current.
Where should we start?
Thanks!
Old Aug 16, 2015 | 02:14 AM
poorman212's Avatar
Default Re: accord 01 no dash parking, visor lights
What trim level is the car?
I'd start with the #10 fuse in the pass side under dash fuse box (10 or 15 amp depending on coupe/sedan)
Old Aug 16, 2015 | 06:11 PM
bugenz's Avatar
We checked all the fuses, they are are good.
It is a honda accord 01 EX Sedan 4 Door 2.3L 4CYL V-Tech.
Old Aug 17, 2015 | 02:24 AM
poorman212's Avatar
The EX trim has a tail light relay in the pass under dash fuse box. I'd test the relay and inputs to it when the head lights are on.
Old Aug 19, 2015 | 11:13 AM
bugenz's Avatar
Update: PROBLEM SOLVED!
My lic. plate fuse needed to be replaced...not part of the main problem (I don't think)...
My tech decided to disconnect the battery and check all the fuses. When we connected it solved all the problems.
Any idea why this happened?
Old Aug 19, 2015 | 04:43 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The fuse that protects the license plate light is passenger under-dash Fuse No. 10, which is the small light fuse and was related to your main problem...
Old Aug 19, 2015 | 07:58 PM
bugenz's Avatar
Thanks poorman!!!
Old Aug 22, 2015 | 04:31 AM
poorman212's Avatar
Just glad you got it going
I should have been clear on what all the #10 pass under dash fuse protects/powers
distra
Apr 20, 2017 11:32 PM
Cor10Bal
Classic Hondas
Aug 24, 2012 03:30 PM
2hondas_noluck
Dec 25, 2008 07:46 AM
POLODOG
Apr 12, 2008 09:50 PM
peachykeenwight
Apr 12, 2007 04:52 PM
