Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
A/C clutch not engaging
Old Aug 10, 2015 | 12:07 PM
orgchm's Avatar
Icon6 A/C clutch not engaging
Hello all! After getting ripped off on an A/C repair on my 2006 Honda Accord EXL, I have decided to take matters into my own hands, but I need a little help.
Symptom: A/C clutch does not engage, both fans run.
I went through the a/c compressor clutch circuit troubleshooting as follows: Tested the fuses, ac relay, clutch and the conductivity and power to the relay and the PCM. Everything appears good. When I short the relay the clutch engages and the A/C blows cold air, so I know the refrigerant and compressor are good (it’s a brand new compressor…they sold me a new one with out fixing the problem!)
The only things that I didn’t test in the service manual was the ECT Sensor temperature and the TP Sensor voltage because I wasn’t sure how.
Does anyone know what is causing this problem? I suspect it is a bad PCM, but I heard those rarely fail. I’m tempted to just install a manual switch that will engage the clutch. Is this a bad idea? Please help! It’s so hot out…
dannydarkman
May 27, 2018 06:27 AM
BLKFLSH
18
Oct 20, 2010 05:44 PM
all-mtr-teg
Mar 1, 2008 11:32 PM
oranginal
Jun 16, 2007 07:39 PM
