Knock sensor plug!!!
Old Aug 9, 2015 | 01:57 PM
Randyb18's Avatar
Default Knock sensor plug!!!
I need to know what harness do you plug in the knock sensor. I can't find it these are the only ones that are not plugged in????
Old Aug 9, 2015 | 09:26 PM
Entheogen's Avatar
Default Re: Knock sensor plug!!!
From my experience I test continuity from the plug to where the ecu plugs in(search for a ecu pinout for your car) and trace the harness till you find the correct plug.
Old Aug 10, 2015 | 11:46 AM
09chaplak's Avatar
Loves Tossing Salad
Greens your alternator. Knock is usually a single blue wire.
Old Aug 10, 2015 | 02:06 PM
HondaPartsHero's Avatar
Technical Hero
That green is not the alternator, most likely the power steering pressure switch.
Old Aug 11, 2015 | 11:02 AM
Fallriverb16's Avatar
well on my carthegreen is the iacv sensor just throwing ideas i have a b16
Old Aug 11, 2015 | 11:12 AM
2point1's Avatar
Either of them can be for the knock sensor. But looks like the green plug has one wire in it so it could be for the knock sensor,some one change the plug. The gray could be for power steering pressure sensor or Evap purge solenoid but could be for something else. It's hard to say for sure without knowing what the wire colors are in the plug and even knowing the colors it's still tricky to say as some one could have swapped the plugs.
Randyb18
Aug 10, 2015 09:14 AM
Boarderx192
Aug 13, 2005 12:10 PM
T_Rex
Feb 3, 2003 07:43 PM
