All motor Ls 98 civic
1998 ex shell i bought had a painted bay when i bought it
shot of the bay when i got it
was stacking up parts till i had them all to do it
wiring harness i got when i bought the car one,one on the right i didnt end up using
wanted to do something different and my own
like how it came out
not everyone likes it but i built it for me and my dad that is no longer alive to show him i could build my own car
how i got the wiring harness all tangled up
paid a kid 40 bucks to untangle it for me
monuts im using right now but have some innovative ones i bought for 150 i will post a pic of later on in this thread
spec d exhuast for now
new axles
i know you dont need msd but at the time i bought it i got a deal on it 112 for cap rotor and coil
65for the 6 a box thats not bad deal if you ask me
motor is re built
blox high compression valves blox dual valve springs blox ti retainers super tech valve lock keepersblox intake manifold
think i have the ones on the left installed but i dont remember they have header wrap on them now
gsr oil pump
arp rod boltsarp flywheel bolts
xenocron sst chip kit i got for my p75 ecu
think this only picture i have of head studs right now
ecu im using p75 wit obd 1 jumper
brian crower stage 2 403 cams i got for 80 bucks and crx carbon fiber mirrors
new radiator and fan i bougth off nw carpart for 100 bucks
knew i had to upgade the suspension at some point
even had to buy a cowell
sub frame and tie bar,the tie bar would not fit for the life of me so i traded it and a blue aem fuel pressure regulator for a whole ls motor
had it together
wasgoing to use a cable tranny at first,bought the mount kit and everything ended up going hydro instead
jdm gsr tranny i got for 50 bucks but the casing had a hole in it but i didnt know at the time but i recently found a ls transmission with no diff for 100 bucks and was going to have it swaped into the ls casing.i have a ls transmission in my car now but since i am replacing the clutch i might as well see if i can get the gears swapped while it is out of the car
was starting to put it together
before i had the motor in it
was about to put it in
in and on mounts
tein lowering springs i bought for 75 bucks
painted them
needed a test pipe
slot and drilled rotors
did the wheel bearings to
i forgot arp extened studs to
suspension on i broke every bolt trying to get the stock ones out
upgrading the camber kit to buddy club next week
how it looked
the bushings were a pain in the *** but worth it cause i dnt even feel bumps
rear drums and brakes i bought a rear disc setup but i gotta buy the rest of the stuff before i put it on
white hood got messed up and fell off the tow truck day i brought it home so i picked up this one for 20 bucks
in and on mounts
painted them
needed a test pipe
how it looked
did rear studs to
new rear struts
steering wheel setup got lock in green
had to cut off that stupid tab that comes at the down pipe
came a long way with her still not done though
up graded fuel pump cause the other one stoped working day after i gotit running
oil light was on because i had that and the temp and oil pressure sensor plug mixed up check engline light was on because tps sensor i had warrenty for new one so i got new one and fixed it
did rear studs to
new rear struts
installed oil pressure guage
got the brass line not the plastic
hid installed
msd
these were a pain in the *** to do
axle boot cam off and grease was geting everywhere fixed it now..energy suspension bushing installed,the bolt broke off in the spot where there is the hole i recently bought j 2 front lower control arms
needed a guage ordered it from jegs
did compensator arms
stock ones were a pain
got it out though
installed them
when i broke the tranny they had put jb welb on ;ike i said though ig to it for 50 bucks it still wokred i got another ls one with no diff i want to swap casings on itended up getting a ls one off my friend for 200 with the shift linkage
see gsr one on the left ls one on the right
stage 1 gonna get a flywheel to got with it
got some better lug nuts
lock setup
bought these after the car show at mogen sun 40 bucks
my lazy dogs
both painted
aunt bought me aem wide band for graduation
hood spacers
got it in finally
was doing some reading up on it
put it in
got some fog lights
monuts i got for 150 few weeks ago
decided to get one
i put it in and did not like how that looked
took the big spacer out and it still looked ugly
said screw it and ordere innovstive shift linkage
finally messed with it last night
thats more like it no big spacer either
got these cause i didnt like the other one
i droped the ole one and the bushing fell out
have to install these next
this to so i can stop my oil leak i even changed the oil pan and i already got a new gasket for it again and torqued it to spec 11 pounds and it still was leaking driven me insane
decided to get one
Is there a point to resurrecting this trainwreck? I mostly just see the same pics over and over. I swear I've seen more swaps with better tech posted by newbs who obey the rules. I would think this belongs in GDD since there is NO TECH.
yes i am back and out of jail,for those that care and are conscerned about it.Im out on parole and working full time at a lumber yard called universal forrest products making trusses,just got hired on to the company.Before on this site may not been the best i remember but that was then and that was before.Few months i was locked up i learned alot and to appericate the simple things.Had my son so i got my priorties in order and started to do things right.Many of you may not be inpressed but thats ok thats not what this was for.Im never gave up .If you guys want to close my thread thats fine but im just saying im not here to argue or lash out at anyone,just feels good to be free and contribute back to society and be free to do as i please like work on my car.If any of you have some advice,not trying to be a smart *** will be appericated thank you for everyones time
