Honda Civic EX injecters
Of course changing to larger injectors would change your fuel economy numbers!!
You also have to get a cold air intake or go forced induction to restore your stochiometric ratio (14.5:1 Air/fuel ratio ) which is the ratio needed to properly burn fuel.
I have no positive answer for the injector capacity, but 450cc to 750cc would be the range you need to look at.
S2000 or Si injectors if you want to keep them in the family, or maybe Pilot. Ridgeline or at the outside NSX injectors.
Steelio
Honda Civic (2001 - 2005)
Aug 24, 2018 02:05 PM
