Need help with hondata s300 p28
Old Aug 3, 2015 | 04:12 PM
goinfast's Avatar
Default Need help with hondata s300 p28
Ok, so I'll try not to make this to long, I have an h22 ek hatch and I keep throwing a cel code 21, vtec spool. Now everything I have read on this code is so vague. I have taken off the vtec, and cleaned it, replaced the gaskets, regrounded, and put back on. Then reset the ecu. It's runs great for about 300 or so miles and comes back. What's my next step? How do I find out if it's the ecu? When the cel comes on the car goes into limp mode and I'm back at square 1 again.
Old Aug 4, 2015 | 09:45 PM
ThE HeLLRaZoR's Avatar
Default Re: Need help with hondata s300 p28
Make sure the Activation conditions are setup correctly and your engine makes proper Oil Pressure(although doubtful this is the issue)
Make sure the Vtec Pressure switch is Disabled(Unchecked).
I'm sure your Vtec Solenoid is malfunctioning tho.
To get rid of the CEL popping up Just (Checkbox) "Disable spool error check"
Old Aug 4, 2015 | 09:46 PM
To get rid of the CEL popping up Just (Check) "Disable spool error check"
Old Aug 5, 2015 | 11:45 AM
goinfast's Avatar
Thank you, I will try that tonight and see if it works
Critikul
Mar 1, 2012 05:54 AM
wrx'n you
Feb 3, 2007 01:07 AM
wutupnut
Apr 15, 2005 06:34 PM
Forrest Gump 9
Aug 11, 2003 05:26 PM
WhoNose
Dec 20, 2002 02:06 PM
