95 GSR jdm into 99 civic ex HELP.
In the EK ('96-00 civic) chassis, it is common to remove the hard pipe and soft pipe that you have circled and simply run a single long 5/8" heater hose between the water pipe under the intake manifold (between the water pump and thermostat housing) and the heater core port on the firewall. It would connect to the port that does NOT have the box containing the valve door. Another alternative would be to purchase a '97 Integra GSR heater hose that goes between the hard pipe you pictured and the heater core.
parsapour
Apr 28, 2018 08:57 PM
hmtcrxsir
Apr 26, 2010 08:23 PM
