Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 civic ex "randomly" stalling
Old Jul 30, 2015 | 01:56 PM
renots128's Avatar
Default 2001 civic ex "randomly" stalling
The hotter a day it is...the worse this gets. Usually after 35-40 mins of driving my car will just stall.....i can turn the key to off and the car will restart for a bit...sometimes 10 seconds and sometimes the rest of the way home, depending on how hot it is so it seems. I have tried researching this and have found everything from main relay failure to igniter to coils to coolant temp sensor to fuel pump...I dunno where to look. Btw, it throws multiple codes when it dies...high input codes on just about every dang sensor on the motor...cam pos, vtech, etc, etc, etc.... PLEASE HELP THIS IS MY DAILY DRIVER!
Old Jul 30, 2015 | 02:51 PM
Steve340's Avatar
Default Re: 2001 civic ex "randomly" stalling
you gonna need someone with a scanner that records, and drive it until it dies. I could be wrong, but the amount of codes are because the engine quit running while the car was on and in motion. It may not even be an electrical issue, might be mechanically induced.
Otherwise, its change the cheapest most likely part and so on and so on.....
Steve
Old Jul 30, 2015 | 04:30 PM
renots128's Avatar
Steve
Well...i have access to a scanner that hooks up to a laptop and can be used as a data logger...would that help?
slang6
Apr 23, 2018 10:12 AM
gotboosthatch
Apr 5, 2013 10:10 AM
attaji123
Apr 16, 2012 01:40 PM
96redexcivic
Jan 24, 2010 02:41 PM
thannon2
Jan 15, 2009 11:37 AM
