E Brake light comming on while revving hard.
Old Nov 5, 2002 | 05:10 AM
Hybrid 350GT's Avatar
Default E Brake light comming on while revving hard.
My e-brake light comes on if rev hard in the 5000-Redline area. This happens in every gear. It just started last night. No electrical work has been done on my care in 2 months. Anyone know why or how this is possible. Thanks for your help.
Old Nov 5, 2002 | 05:15 AM
ITR764's Avatar
Default Re: E Brake light comming on while revving hard. (DOSPOWND)
add brake fluid.
Old Nov 5, 2002 | 05:23 AM
hungsteR's Avatar
Default Re: E Brake light comming on while revving hard. (ITR764)
add brake fluid.
Old Nov 5, 2002 | 05:46 AM
Dave-ROR's Avatar
add brake fluid.
and if brake fluid is full, the sensor in the cap might be bad. (cheap to replace the cap if that is what's causing it)
Old Nov 5, 2002 | 10:04 AM
iperez's Avatar
Its a message from God telling you to slow down man !!!! hahahaha !!! Just kidding, do the fluid check.
Old Nov 5, 2002 | 10:51 AM
SloEG's Avatar
Default Re: E Brake light comming on while revving hard. (iperez)
You're alternator might be going bad. My e-brake light came on when my alternator was bad, once vtec hits, it goes off.
Old Nov 5, 2002 | 11:12 AM
TypRice's Avatar
i had some what the same prob. it was the fluid!
Old Nov 5, 2002 | 11:44 AM
Default Re: E Brake light comming on while revving hard. (TypRice)
Thanks for the help, I just did check the fluid and it is very low, alomst at MIN line. I'll fill 'er up. I should be paying more attention to my fluids.....
Old Nov 5, 2002 | 08:12 PM
Bills01ITR445's Avatar
my radio cuts off at high revs sometimes, anybody ever had that problem?
Old Nov 5, 2002 | 08:13 PM
B2FiNiTY's Avatar
Default Re: E Brake light comming on while revving hard. (Billz01ITR445)
Sounds like alternator? What about your headlights?
Old Nov 5, 2002 | 08:23 PM
Default Re: E Brake light comming on while revving hard. (B2FiNiTY)
i have noticed them getting dimmer, probably alternator huh?
Old Nov 5, 2002 | 08:24 PM
Reid's Avatar
Global Moderator
I'd bet on the battery dying out before the alternator.
Old Nov 5, 2002 | 08:27 PM
Dave-ROR's Avatar
check those pads out. If it's that low and nothing is leaking than the pads are nearing the end of their life.
ej6kid
Nov 1, 2010 06:55 PM
Z7
10
Aug 6, 2006 01:17 PM
type r 01-1063
Apr 3, 2003 11:04 PM
ITR#JohnBasedow
Dec 9, 2002 08:01 AM
nsx-Animal
Jul 29, 2002 11:54 AM
