BC Stg 2 NA cams into ITR
Old Jul 27, 2015 | 02:39 PM
Touge/Wangan's Avatar
Default BC Stg 2 NA cams into ITR
hey guys,
I have a Type R with a JDM 2000 ITR engine in it, I recently installed Brian Crower Stage 2 NA cams and I'm slightly concerned that the valvetrain might not be up to par, these are the cams I purchased.
http://www.briancrower.com/makes/honda/b16ab18c.shtml
the BC STG2 cams have a lift of 11.99/11.99mm where my valvetrain seems to be rated for a little less according to this link
Discussion about valve spring requirement
Acura USDM 98-01/JDM 96-01 ITR Valve Springs
Variable or Linear: Linear
Seat Pressure: 50lbs
Max Lift: 11.5mm
Coil Bind: 11.7mm
Pressure @ 11.5mm/.453" lift: 150lbs
thanks for any advice and help, it's appreciated.
Old Jul 27, 2015 | 02:50 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Default Re: BC Stg 2 NA cams into ITR
Coil Bind: 11.7mm
You really answered your own question.
You need to replace your valvetrain with those cams.
The only aftermarket cams I know of that don't require new springs are Skunk2 Tuner 1s, and Buddy Club Spec 3.
Old Jul 28, 2015 | 07:09 AM
I'm going to replace the cams with the original 98+ spec cams until I get valve springs, a slight oversight on my behalf. my other integra had a build head so I didn't think twice.
could there be any potential damage done by doing this? I drove the car nicely, under 4000rpm for maybe 50miles
Old Jul 28, 2015 | 07:43 AM
2LEM1's Avatar
I like to party
Community Builder
You'd know if you dropped a valve.
You're fine.
Old Jul 28, 2015 | 09:05 AM
that's good to hear, I pulled the valve cover to take a quick inspection and this is what I noticed on each cam lobe. I didn't drive the car today, and I'm going to replace the cams tonight with the factory ones. what do you think?
Old Jul 28, 2015 | 12:23 PM
2LEM1's Avatar
I like to party
Community Builder
They look like cams
Old Jul 28, 2015 | 02:05 PM
lol, thanks. I meant the weird wear just as the lobe tapers. I must be over thinking about this.
Old Jul 28, 2015 | 02:38 PM
2LEM1's Avatar
I like to party
Community Builder
You are.
I see the marks you are talking about, but they don't look they are dug into the cam, it looks like a surface abrasion. I don't know what caused it, but it's not really a big deal, if you understand how cams work, that shouldn't cause any issues. I would definitely change out the valvetrain though, if you do end up hitting VTEC you will most likely coil bind those springs and drop a valve and experience catastrophic engine failure.
Old Jul 28, 2015 | 03:02 PM
the 98's are going back in tonight, I'm just nervous that the rocker arms (I believe?) could have the same markings / damage now, no idea what could have caused them. my friend suspects bad casting on the cams themselves, but look "normal" to him as if they're "polishing" or "breaking in" kinda-thing, there's a texture difference but that's it, and the markings are identical on each cam lobe, a generous amount of assembly lube was used in the installation, and everything torqued to spec.
Old Jul 28, 2015 | 03:21 PM
2LEM1's Avatar
I like to party
Community Builder
IDK, I'd ask someone like Derek what he thinks, but they look fine to me.
I really miss Don F.
Old Jul 28, 2015 | 06:35 PM
ojasia's Avatar
Ya that lift is the max lift @ Vtec, the primarys and secondary dont lift that much unless you had Drag/strip Vtec killer camshafts.
Old Jul 28, 2015 | 07:22 PM
2LEM1's Avatar
I like to party
Community Builder
Correct. Meaning if you don't hit VTEC, you won't have a problem. So if you really stayed below 4K, no harm no foul. But if you switch over to that VTEC lobe, you're going to have a bad time.
Also, I'll see about having this moved to All Motor so the right people can see those cam marks.
Easyslider01
Oct 7, 2006 04:23 PM
DA-9mordef
Apr 27, 2006 10:04 AM
lvbuckeye
Jun 10, 2004 06:21 PM
TurboTeG4
Dec 15, 2003 07:17 PM
