Suspension & Brakes Theory, alignment, spring rates....
NSX Rear brake swaP??
Old Jul 27, 2015 | 07:52 AM
Blutz3's Avatar
Default NSX Rear brake swaP??
Hey guys, I have a 94 civic that I am running 91 NSX calipers on with mini cooper rotors and Project MU pads. I am still running rear drums and would like to do an NSX rear brake swap. My question is would the braking force be excessive due to NSXs rear calipers compensating for mid engine placement? I have read into doing this and also viewed the brake swap posts and it appears as it cannot be done... but I have seen pictures online with people running the rears. Any help would be appreciated.
thanks!
Old Jul 28, 2015 | 04:02 AM
Fitz Williams's Avatar
10 Year Member
Default Re: NSX Rear brake swaP??
The NSX uses ventilated rotors that are about 10mm thicker that the non-ventilated kind, so something would have to make up the difference. And yes, the braking force would be a lot more that what you need to balance it out, so you would need to install some means of metering off the pressure to the rear.
Old Jul 28, 2015 | 04:04 AM
Blutz3's Avatar
Gotcha. Iv been reading into it more and im gonna go with a wilwood or upgraded oem style caliper. Thanks!
Old Oct 27, 2015 | 10:02 AM
Turtle808's Avatar
I don't know if you still have abs or not, but if you have deleted it, you could possibly use a tilton valve on appropriate hardware to change bias without having to change pads with different combos of bite to accomplish the same thing.
blazzer
10
Feb 27, 2010 10:43 AM
e30cabrio
Suspension & Brakes
Dec 20, 2009 02:06 PM
sjbmx
Jun 11, 2008 03:41 AM
Si_Allen
Jan 10, 2007 02:07 PM
FuNkDrSpOt
Oct 3, 2006 08:37 PM
