96 Accord positive grounding
With the negative battery cable, starter and alternator disconnected my positive post hast continuity with the engine and grounds. Any ideas. Any common problems like this
Actually now that I think of it, if you had a short to ground on a fused circuit it should blow the fuse.
Hate to ask this but are you sure your battery isn't sitting in there backwards ?
The negative terminal is always facing the outside of the vehicle.
It isnt in backwards. First thing I checked. Maybe a bad starter solenoid. It clicked when attempting to start but no response from the starter itself
The solenoid was extremely HOT!
cityofcaterpillars
Sep 27, 2016 11:53 AM
sparxx
Jan 6, 2004 02:46 AM
