speedo and D4 probs
Old Jul 25, 2015 | 06:08 PM
crackers's Avatar
Default speedo and D4 probs
G'day all I have just bought a 95 accord. And the speedo does not work. Also I have the D4 light flashing along with but not all the time engine fault light comes on after a few klms then goes off when it feels like it. I'm a pensioner so $ are tight and try to fix things myself. I would appreciate any advice given thankyou
Old Jul 25, 2015 | 06:42 PM
onunezp's Avatar
Default Re: speedo and D4 probs
easy fix, its the vehicle speed sensor, or VSS, same thing happened to me and 13USD sensor from amazon did the job, and clear the flashing D4 and check engine light.
Old Jul 25, 2015 | 06:51 PM
MAD_MIKE's Avatar
MM Gruppe B
Find the blue two wire connector on your car. Depending on where you are located the diagnostic connector is located in different position for different region Accords.
Jumper the two wire connector with a paperclip, turn the ignition to II(ON) and count the blinks from the CEL and D4 lamps. Longer blinks are multiples of 10, shorter ones are multiples of 1.
___ ___ ___ = 30
_ _ _ = 3
Old Jul 25, 2015 | 07:41 PM
crackers's Avatar
[QUOTE=onunezp;50453504]easy fix, its the vehicle speed sensor, or VSS, same thing happened to me and 13USD sensor from amazon did the job, and clear the flashing D4 and check engine light.[/QUOTE ] Thanks for the advice this sure beats going to either dealer or auto elec again thanks cheers
supaf1y
Jul 30, 2007 09:16 AM
98IntegraLSNonVtec
Dec 24, 2005 11:52 AM
shaveman
Aug 7, 2005 03:37 AM
CaptainObvious
Aug 18, 2003 04:41 PM
