Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
A/C not working even after some test
Old Jul 25, 2015 | 12:45 PM
mugen94's Avatar
Default A/C not working even after some test
Hi, on my 03 civic, the compressor clutch and condenser fan do not engage when I press the AC button , here is the test I have done
-all my relay and fuse are tested and are good
-I have jumped the condenser fan from the fuse box and it does turn
-I have jumped the compressor clutch from the fuse box and it engage and it blow cool air inside the car but the idle stay the same
-I have unplug the pressure switch jumped the 2 wire together and then try to pu AC on but nothing happen
so the compressor and fan are good but it does nothing when I press the AC button.. it seems that there is no power going to the relay to activate
what is the next test I can do ?? thanks
Old Jul 27, 2015 | 01:27 PM
mugen94's Avatar
Default Re: A/C not working even after some test
bump
Old Jul 30, 2015 | 10:18 AM
CheekedUP's Avatar
I'm having the exact same issue. 02 JDM EP3. Exactly the same problem and my local Honda garage are lost with whats causing it. They actually told me to google it, which brought me here
Old Aug 3, 2015 | 02:35 AM
slowcivic2k's Avatar
You'll need a schematic for your car, if you can find one, I will help you to the end.
I can haz A/C.... https://honda-tech.com/tech-misc-15/...oesnt-2900177/
DaX
21
May 23, 2019 09:27 AM
Xjbw1983
Aug 30, 2016 01:49 PM
jsazc777
Sep 7, 2015 07:12 AM
ewgoforth
Sep 9, 2014 07:13 AM
C8V6C
Jul 21, 2005 09:21 PM
