D16Z6 running on P2P ecu
Old Jul 25, 2015 | 04:53 AM
aaron-'s Avatar
Icon2 D16Z6 running on P2P ecu
From what I have found online, I didn't think it was possible to run a d16z6 on an OBD2 ecu due to timing issues. I have recently picked up a 98 civic sedan that has been swapped to a z6 from a 94 si by the previous owner and it seems to be running on the P2P ecu.
I have pulled out the ecu from under the kick panel and there is no OBD2-OBD1 jumper harness attached. I was hoping to find a P28 attached to do a small tune on, but there was only the P2P and ABS control unit.
I would just like to know if it is possible to run the z6 on a OBD2 ecu.
Old Jul 25, 2015 | 06:12 AM
Srtk4l's Avatar
Default Re: D16Z6 running on P2P ecu
Do u have a cel on?
Old Jul 25, 2015 | 10:48 AM
aaron-'s Avatar
Originally Posted by Srtk4l
Do u have a cel on?
It didn't have one for the first month or so when I bought it and it passed e-test at that time. It recently threw a code for an air temperature sensor that I believe was caused by faulty wiring done by the previous owner.
Old Jul 25, 2015 | 10:57 AM
Srtk4l's Avatar
Well I know on my em1 I was having the same issue. And I threw a code for iacv idle air control valve. U can try cleaning. Reset battery. If it still remains. I've seen some on sale for like 40$.
Old Jul 25, 2015 | 03:53 PM
aaron-'s Avatar
I'm not worried about the code, I was just wondering how my OBD1 motor is running on an OBD2 ecu
Old Jul 28, 2015 | 04:21 AM
eghatch9295's Avatar
Stancetard Hate Monger
with a ckf bypass, knock sensor installed, jumpered dizzy or obd2 guts in a z6 case, y8 intake manifold.
Zach Barrette
Sep 14, 2017 02:59 AM
95_eGsix
Jun 25, 2012 02:42 PM
ekphil
Sep 23, 2011 08:41 PM
H22ADelSol
Apr 27, 2003 05:37 PM
