1993 Del Sol, Should the ECM output 3 volts to relays? (cooling fan not turning on)
Old Jul 20, 2015 | 10:44 AM
navila17's Avatar
Default 1993 Del Sol, Should the ECM output 3 volts to relays? (cooling fan not turning on)
Cooling fan is not turning on. It does not seem to be the fan motor, relay, OR the thermoswitch. Here is what I know:
-Not getting any voltage at the fan
-Fan motor works when directly supplied with 12 volts
-Jumping the thermoswitch does not turn on the fan, or provide any voltage at the fan connector
-Switched relay with known good relays, jumped the thermoswitch, fan still does not turn on
-Reading the voltage on the signal side of the relay, it only reads about 3 volts when I jump the thermoswitch
So that is my main question, should the ECM be putting out 3 volts on pin A12 to the relay? Or is it supposed to be putting out 12 volts?
Thanks!
-Nick
Old Jul 20, 2015 | 01:30 PM
navila17's Avatar
Default Re: 1993 Del Sol, Should the ECM output 3 volts to relays? (cooling fan not turning
I was playing around a little more:
Measuring from ground to the 2 signal pins going to the relay, one pin reads 12 volts, one reads 0.4 volts, with or without the thermoswitch jumped.
But if I measure between the 2 signal pins, I get 0 with the switch open, and ~3 volts with the switch jumped.
I am pretty confused. One of the signal pins should be ground, shouln't it be?
Any ideas?
Old Jul 21, 2015 | 07:07 AM
Former User's Avatar
Test fuse 13.
19 crx 89
10
Aug 26, 2010 12:38 PM
xTomei
10
Jun 7, 2010 06:02 PM
Ldo
Dec 8, 2008 11:43 AM
Jonathan_ED3
Sep 27, 2008 10:11 AM
Run Away
Jun 7, 2008 10:12 AM
